Starting troubles with my JD F925 front mower
   / Starting troubles with my JD F925 front mower #1
JoefromCroom
Upper Marlboro, Maryland
John Deere F925
Hello one and all,
Just joined in and I am hoping there are those that may help me with my John Deere F925. While I was preparing for the 2016 grass cutting season, I have been doing Preventive Maintenance to get ready. While cleaning the battery terminals and cable, I had to replace a cable terminal connection. No problem. Once I buttoned up everything, I tried to start her and nothing. I found the battery was dead, so I replaced it. I checked it with a battery tester before installing it and it checked out okay. I installed it, secured it and then tried to start it. I am on the seat with the parking brake on. I wait till the fuel pump chimes in for a couple of seconds, then try to start it. It didn't even get close then I hear what sounded like a circuit breaker going out and it sounded as if it came under the right side panel. HELP! I don't have a Technical Manual and the Owners manual doesn't go there. Any help would be greatly appreciated! Thanks!
Hello again,
In reference to starting my JD F925, I have found that the 6 plug modulator under the right side panel Makes a loud click when I try to start her up, then all goes dead. If I remove the modular for about a minute and then plug it back in an turn the key on, everything lights up again. When I try to start her, the modulator pops again and all goes dead. Do I have something that is not in the right position, or something that doesn't short out till I try starting it or do I simply replace the modulator?
   / Starting troubles with my JD F925 front mower #3
Have you reversed the battery cables ?
   / Starting troubles with my JD F925 front mower #4
I have a PDF of the tech manual that you're welcome to, shot me your email if wanted
Joe
Hey Joe,
Thanks for the offer for the Tech Manual. I have one already, thanks. Its not helping me get to the root of my problem but I'm going back through everything I've done. Hopefully, I will find the problem and correct it.
Hello ZZVYB6,
Understandable question but no. I did find due to battery post position relative to the cable layout, that the cables were crossing each other. I have taken measures to correct this problem. Thanks for your input.
Hello once again ZZVYB6 and all others who pitched in,
As i stated, I had to re-route the positive cable , as it was short of the post on the battery. Once that was corrected, wire tied in place and cables hooked up, I put the seat back down, sat down and gave her a try. She fired right up!
I was surprised that, even with an additional insulator sleeve on the positive battery cable, that its crossing the negative cable was causing the trouble that I never had before cleaning the terminal clamps. Weird.
Anyway, Thanks to all for your help!
2019 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A52705)
2019 CATERPILLAR...
2018 FORD TRANSIT T150 CARGO VAN (A54313)
2018 FORD TRANSIT...
2011 FORD F-550 (A53843)
2011 FORD F-550...
PumpJack Brand Pump Jack (A53473)
PumpJack Brand...
2017 Takeuchi TL8 (A47477)
2017 Takeuchi TL8...
1989 TRAILMOBILE 45X96 SPREAD AXLE FLATBED TRAILER (A53843)
1989 TRAILMOBILE...
