STARTING TROUBLE SATOH BEAVER TRACTOR
   / STARTING TROUBLE SATOH BEAVER TRACTOR #1
begare
RECENTLY GOT SATOH BEAVER S370. TRANSPORTER JUMPED OLD BATTERY AND STARTED. ABOUT 2 WEEKS LATER UNABLE TO START, EVEN W/ NEW BATTERY (RETESTED BATTERY AND IS GOOD). COULD BE I DON'T HOW TO GET GLOW PLUG ETC GOING CORRECTLY. ANY ADVICE. NO OWNER'S MANUAL.
   / STARTING TROUBLE SATOH BEAVER TRACTOR #2
Turn key to glow plug position for 10sec in warm weather and 20-30 in cold, pull throttle lever to the start position and turn key to start position.
   / STARTING TROUBLE SATOH BEAVER TRACTOR #3
got fuel? fuel turned on?
making any smoke while cranking over?
soundguy
   / STARTING TROUBLE SATOH BEAVER TRACTOR #4
What Soundguy said. Is the starter turning the motor over? If so and if it's making a little smoke while spinning the motor then you should be getting fuel. Are you giving it some throttle?
   / STARTING TROUBLE SATOH BEAVER TRACTOR #5
along with all those other things mentioned, you may want to check the ground connection at both the battery and the frame (under dash). i had some issues with corrosion where the cable mated with the cable clamp. in addition, on my beast, the fuel lever should be in the "vertical" position to open the valve. this always seemed counter-intuitive to me, but then . . .
bestests---
thommy lee d.
   / STARTING TROUBLE SATOH BEAVER TRACTOR #6
If it turns over and doesn't start
Is the shut off knob pushed back in?
The glow plug indicator is that chrome disk on the dash that has a hole in it can you see that glow when you turn it to glow position?
If it won't turn over at all check Both ends of battery cable paying special attention where the ground hooks up . I have had problems with the grd before and have run the GRD wire back to the starter bolt.
1839 (A51248)
1839 (A51248)
2014 GMC Sierra Pickup Truck (A50323)
2014 GMC Sierra...
PLEASE CHECK BACK!!! ITEMS BEING ADDED DAILY!!!! (A50775)
PLEASE CHECK...
2018 KENWORTH T370 T/A DUMP TRUCK (A51406)
2018 KENWORTH T370...
2020 Kia Soul SUV (A52377)
2020 Kia Soul SUV...
CASE 580 (A47477)
CASE 580 (A47477)
