Starting question on 30HP Mitsibishi Diesel
   / Starting question on 30HP Mitsibishi Diesel #1
32Ford
Wisc
Farmtrac 300DTC
My tractor has a 30 HP four cylinder Mitsubishi motor with 50 hours on it. The last two times I started it, it started fine but maybe on only 3 cylinders. After maybe 5-10 seconds it smooths out fine and runs great. I plan on talking to the dealer about this but would like to get an idea what might cause this. It is under warranty, this is my first diesel and just want to have some knowledge about what might be going on before I talk to him.
Thanks
   / Starting question on 30HP Mitsibishi Diesel #2
Does it have individual glow plugs for each cylinder? If so, maybe one is bad.
   / Starting question on 30HP Mitsibishi Diesel #3
Sounds like a partially clogged injector...suggest you start it, warm it up, then run the livin' heck out of it for an hour or two. This will not hurt a diesel and sometimes will "flush" the system out. BobG in VA
   / Starting question on 30HP Mitsibishi Diesel #4
Any fuel leaks at the injector lines.. if one o fthem is becoming air-logged.. it will take a few secs to purge upon starting.. just like bleeding.. etc..
soundguy
2015 Clarke Power Gen RC60D 47kW Towable Diesel Generator (A50324)
2015 Clarke Power...
Cruise Car Electric Utility Cart (A51691)
Cruise Car...
(2) METAL SPOOLS W/ SOME DURALINE 4" PVC PIPE (A51248)
(2) METAL SPOOLS...
(APPROX 18) 2" X 6" X 68" THICK TUBING (A51247)
(APPROX 18) 2" X...
Pitts Tri-Axle RGN Lowboy Equipment Trailer (A50322)
Pitts Tri-Axle RGN...
2015 TAKEUCHI TB260 EXCAVATOR (A51246)
2015 TAKEUCHI...
