starting problems
/ starting problems #1
ab1953
PA
john deer b john deere 4600 international 300
I have a john deere 4600 and it has been having a lot of electrical issues. Now it will not turn over when trying to start it. The battery is good and powerful but it just clicks when I try to start it. I would appreciate any help I can get.
/ starting problems #2
There is always a story behind everything. "a lot of electrical issues". Can you elaborate? What clicks?
/ starting problems
I have been having problems with it turning over but not starting. I replaced the fuel solenoid. That didn't help. I checked the safety switches and cleaned the wire where they contacted the switch and it started. Then after several days it started but wouldn't shut off. Thought it was a relay so pulled all of them out and cleaned the terminals and it shut off. Now I try to start it and it just clicks and if I try it several times it smells like a wire getting too hot.
/ starting problems
The starter solenoid is what clicks.
/ starting problems #5
Either bad starter cable connections, or simply a bad starter. I have also had to clean up the contacts in a solenoid more than once.
/ starting problems #6
a common problem that will often cause this is the battery ground wire where it connects to the engine/frame will rust and not make a good enough connection to allow the necessary amps for the starter to turn over even if the battery is good. check and clean battery positive and ground connections also.
New/Unused CFG Industrial NT18K Mini Excavator (A65583)
New/Unused CFG...
RIDGID AIR COMPRESSOR (A65643)
RIDGID AIR...
1/2" Quick Attach Blank Plate (A66408)
1/2" Quick Attach...
2023 JOHN DEERE 550P LGP CRAWLER DOZER (A64279)
2023 JOHN DEERE...
(2) Firestone Tires (A65640)
(2) Firestone...
New/Unused AGROTK Tire Changer (A65583)
New/Unused AGROTK...
