starting problems
   / starting problems #1
ab1953
PA
john deer b john deere 4600 international 300
I have a john deere 4600 and it has been having a lot of electrical issues. Now it will not turn over when trying to start it. The battery is good and powerful but it just clicks when I try to start it. I would appreciate any help I can get.
   / starting problems #2
There is always a story behind everything. "a lot of electrical issues". Can you elaborate? What clicks?
   / starting problems
I have been having problems with it turning over but not starting. I replaced the fuel solenoid. That didn't help. I checked the safety switches and cleaned the wire where they contacted the switch and it started. Then after several days it started but wouldn't shut off. Thought it was a relay so pulled all of them out and cleaned the terminals and it shut off. Now I try to start it and it just clicks and if I try it several times it smells like a wire getting too hot.
   / starting problems
The starter solenoid is what clicks.
   / starting problems #5
Either bad starter cable connections, or simply a bad starter. I have also had to clean up the contacts in a solenoid more than once.
   / starting problems #6
a common problem that will often cause this is the battery ground wire where it connects to the engine/frame will rust and not make a good enough connection to allow the necessary amps for the starter to turn over even if the battery is good. check and clean battery positive and ground connections also.
Payment Terms (MUST READ) (A50775)
Payment Terms...
(4) STEEL CARTS (A51248)
(4) STEEL CARTS...
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
Ryobi Compound Miter Saw (A51573)
Ryobi Compound...
2014 Dodge Charger Sedan (A51694)
2014 Dodge Charger...
U56 DIESEL FIRE PUMP (A51406)
U56 DIESEL FIRE...
