I would leave that can of ether, alone. These diesels have very high compression, and they can blow up, with ether. Might ruin the motor, it might even ruin you. Just get the air out of it and it will start and run fine. But ether, gas or any other suppose to be short cut, just wouldn't get it started, as long as it has air in the lines. Like the man said, now that you have let yourself run out of fuel once, you probably won't let it happen again, at least for a long time. /forums/images/graemlins/smile.gif
