Starting Problems
Status
Not open for further replies.
/ Starting Problems #1
MudtrekkerMD
Maryland
Cub Cadet 4wd Hydrostatic 7275
My 3 cyl diesel tractor is not starting correctly. When I turn the key, nothing happens but the gauges start working. If I jiggle the PTO levers to engage the sometimes troublesome sensor switch, it still makes no difference.
If I keep trying to start it, it eventually will start up but it seems to be getting worse every time. Is this a symptom of the starter solenoid going bad?
Will replacing the starter solenoid solve this starting problem?
It's getting so bad that I'm afraid one day it won't start when I really need it.
The tractor is a Cub Cadet 7275 Hydrostatic.
Thanks for applying all the great wisdom of you forum members to this little problem of mine.
Mudtrekker
Status
2021 PETERBILT 388 6X4 T/A SLEEPER TRUCK TRACTOR (A59911)
2021 PETERBILT 388...
2015 Freightliner M2 106 AWD Altec DM478BTR Insulated Digger Derrick Truck (A60460)
2015 Freightliner...
COMBINE RIM FOR JOHN DEERE (A63291)
COMBINE RIM FOR...
2007 MACK CHN613 6X4 T/A DAY CAB TRUCK TRACTOR (A59909)
2007 MACK CHN613...
2022 Braxton Creek Freesolo KITCH 18 ft Travel Trailer (A61574)
2022 Braxton Creek...
2015 Hitachi ZX210LC Hydraulic Excavator (A61572)
2015 Hitachi...
