Starting Problems
/ Starting Problems #1
MudtrekkerMD
Maryland
Cub Cadet 4wd Hydrostatic 7275
My tractor is not starting correctly. When I turn the key, nothing happens but the gauges start working. If I jiggle the PTO levers to engage the sometimes troublesome sensor switch, it still makes no difference.
If I keep trying to start it, it eventually will start up but it seems to be getting worse every time. Is this a symptom of the starter solenoid going bad?
Will replacing the starter solenoid solve this starting problem?
It's getting so bad that I'm afraid one day it won't start when I really need it.
The tractor is a Cub Cadet 3 cyl Diesel 7275 Hydrostatic.
Thanks for applying all the great wisdom of you forum members to this little problem of mine.
Mudtrekker
/ Starting Problems #2
No one can give you the answer you are looking for without troubleshooting the starter control circuit. There is a point somewhere that power should be continuing on to the next component but it is not. A wiring schematic, and a low end VOM or possibly just a decent 12V test light will be required.
/ Starting Problems #3
As rick said.. you need to see how far power is getting to know if it is an interlock, or bad component.
I would put a vom from the starter relay to ground.. or a test lamp. If it shows voltage/glows when you turn the switch.. I suspect a bad relay/starter. if it doesn't.. I suspect something between the key switch ( including the key switch ), and the relay.. like clutch/trans/pto or other operator presence switches.. etc.
soundguy
2021 Ford Explorer Hybrid AWD SUV (A66738)
2021 Ford Explorer...
Set of 2 Unused ST205/75R15 Radial Trailer Tires (A66734)
Set of 2 Unused...
Fecon 72in Mulcher Head Skid Steer Attachment (A66734)
Fecon 72in Mulcher...
AGT QA Pallet Forks (A64912)
AGT QA Pallet...
525 Gal Supply Tank (A64912)
525 Gal Supply...
CASE  721F WHEEL LOADER (INOPERABLE) (A67714)
CASE 721F WHEEL...
