Starting my bridge!!
/ Starting my bridge!!
1/8 deflection in center with pick up
A bit less with tractor
The railing tilted in 1/8 also
Everything moved back when I drove off
44E06D96-D433-46C1-9AB1-525827AE4CCA.jpegABB839B9-10AF-4803-9FB9-7966331A5717.jpeg669CD5FE-00B3-4925-A922-4316695FE5F3.jpeg4C32D633-4BD7-43E6-8536-80B8F5DBE8BD.jpeg7B7C71B6-DE54-4470-8A74-C669408E96C0.jpegDF3672B2-0ADF-423D-A1EF-E5198E993261.jpeg
/ Starting my bridge!! #224
image sent from phone to help with above post.
David from jax
The 3x3 cross tubes are welded to the angles and I tried to get some decent wells from the 3x3 tubes to the 2x6 tubes
/ Starting my bridge!! #227
View attachment 805377View attachment 805378View attachment 805379View attachment 805380View attachment 805381View attachment 805382
Love it!
The tractor was probably a better test since more of the weight is in the middle vs the truck's weight being closer to the abutments.
Consider plugging the ends of the tubes with something so that you don't get wasps or who knows what living in them...
Love it!
Thank you!
I’ve got some sheet metal and caulk……I could cut some 1/8” plate and weld them in…..honestly I’m tired of welding!!
/ Starting my bridge!! #229
Thank you!
Maybe a fitted piece of wood stuck into or onto the end, or if you're into it just glue a rectangular reflector for those nighttime crossings
Was thinking solar night lights.
The reflectors is a good idea also!
/ Starting my bridge!! #231
Great work and congrats on the test run!
TEST YOUR BID BUTTON! (A63291)
TEST YOUR BID...
2007 Ford F-250 Crew Cab Pickup Truck (A61573)
2007 Ford F-250...
2013 Felling 25' x 102 Tag Trailer (A62613)
2013 Felling 25' x...
2006 John Deere 250D 25 Ton Articulated Dump Truck (A59228)
2006 John Deere...
2013 Ford F550 Bucket Truck w/ Jib (A62613)
2013 Ford F550...
Massey Fergusson 4710 (A60462)
Massey Fergusson...
