STARTING KEY JD2010
/ STARTING KEY JD2010 #1
bo50
Western Australia
JD2010
Hello forum. Just after buying my 'new' JD 2010 (19630 I had the bad luck to break the key! So I went to the fence cut of a piece of wire, bent it and pushed it in the slot of the tractor. And it started. Now after a couple of weeks doing just the same thing with the wire (now my key) I get starting problems. Battery gets flat, I don't know if the glow plug works and it is difficult to start even when its warm, after a couple of hours running. So I think the key does more then just the wire and I think I am in need of a new real key. Anyone where I can get that? Living in Western Australia - Porongurup Area. Thanks guys.
/ STARTING KEY JD2010 #2
bo50
You might have to go to a John Deer dealer for a key, I have a Massey Ferguson 1428V and thats what I had to do, no key shop could make a key it was a special key blank.
nextofkin
/ STARTING KEY JD2010 #3
The wire is probably not getting it all the way to the OFF position. It is stuck in Accessory and that is what is draining the battery.
/ STARTING KEY JD2010 #4
I used a 5065M at work and carried a spare key on my key ring and could use it to start ANY JD I came across....
Yes the JD dealer in Albany wants just to sell and advised me to buy a new JD lock: 300 bucks!
Hi Tx Jim. Can I order a key from you? Is that what your message means?
/ STARTING KEY JD2010 #8
Not exactly. A4700R is the part number for the key that any reputable/competent JD dealer should be able to get for you.
Thanx Gonna give that number a try, see how they react at the JD shop.
Thanx a bunch Tx Jim. It Worked! Today I received my keys in Albany Australia! $7.88!!! while they were trying to sell met a whole new lock etc for 300 bucks. Gonna try them tomorrow but I'm sure they'll work. Thanks forum. Great you helped me out!
/ STARTING KEY JD2010 #11
bo50
You're Welcome!! If your tractor has factory switch key should work.
Jim
