Starter wiring trouble.
   / Starter wiring trouble. #1
klc336
international b414
I have an international b414 diesel. The original starter went out and can't be repaired and it had a push rod solenoid. I got a new one and it has an electronic solenoid, but I cannot find an UPDATED wiring diagram to help me. I put it on the tractor and tested it and all it does is click. So I pulled it off and tested it and it works great. It won't throw out or spin on the tractor I've tried everything I know, it's just not making sense to me how I can test it off the tractor and it works fine but when it's on the tractor do the exact same thing and it only click. And no it's not I wiring or ground problem. I'm simply testing by jumping the solenoid no wires are attached to the tractor except the ground and that wire is new
And I've rewired lots of tractors and tested them all this way never had this problem before..
   / Starter wiring trouble. #2
Sound's like there's enough juice to activate solenoid and possibly engage Bendix drive but not enough juice to turn engine over. Test both batteries (if it has two 6 volts). If you leave wires connected and pull starter from bell housing,then starter works,it is (A) battery not fully charged or (B) one or more cables with poor connection or (C) one or more cables rotted inside jacket where you can't see.
I'm not using the tractors batteries or wiring. I'm using a jump box for power and a wire to jump the terminals on the starter. It's not engaging anything other than the solenoid. But it works fine when I do the same thing off the tractor. Only difference is the starter is on the tractor
   / Starter wiring trouble. #4
Same principle applies whether using tractor batteries or jump box. Use alligator clips or have an assistant hold volt meter probes on cable post on starter and starter housing. If voltage is maintained when starter is engaged,starter is defective. If voltage drops,starter might also be defective but cables,connection and battery should be suspect. As I recall,2 batteries are parallel 6volt positive ground,has that been altered?
You are correct it is positive ground. Nothing has been altered yet but I will have to rewire the tractor and add in a new starting key switch do to the new starter not using a push rod solenoid which is why I'm trying to test it like this to figure out which wire's need to go where on the starter and then found out that I cannot get the starter to properly engage.
   / Starter wiring trouble. #6
I would expect the starter to have 1 post that is connected to cable from large post on remote solenoid. Other large post on solenoid connects to negative battery post. Small post(s) on solenoid can be different due to substitutions of various solenoids(all will work but must be wired differently). The correct solenoid has 1 small post that when grounded engauges solenoid. Substituts can have 2 small posts,one marked I for ignition and other marked S for start. The start can require + or - ,depending on which tractor/car/truck it is used on. Can you positively say which and how small post was desighned to engauge solenoid? We can install a push button for start without having to replace key switch.
Yes, its clear. And that's how I've been testing it. Which is why I'm confused
   / Starter wiring trouble. #8
are you jumping it off the tractor as a positive ground? or like a normal ground? is the solenoid wired in a way to handle a positive ground?
   / Starter wiring trouble. #9
I have 2 IH tractors.
I do not know the wiring off the top of my head, but I have experienced the same problem. Motor winding and solenoid both have to engage at the same time.
Well I've been having to do it as a negative ground. When I try it as a positive ground it just archs. I will say this is my first positive ground tractor and I would like to convert it to negative.
2018 Ford Explorer AWD SUV (A51694)
2018 Ford Explorer...
2017 Ford F550 Bucket Truck - Powerstroke Diesel - Auto Trans - 4x4 - Versalift SST40 Boom (A52748)
2017 Ford F550...
1993 Ford F700 Stakebody Flatbed Truck (A51692)
1993 Ford F700...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
2016 Kia Optima Sedan (A48082)
2016 Kia Optima...
2018 JOHN DEERE 672 GP (A52472)
2018 JOHN DEERE...
