Starter Torque
/ Starter Torque #21
The third waveform is from a 1991 Honda Civic, 4 cylinder, 1493cc engine. The compression ratio is approximately 9:1. The inrush current equals 584 amps, but only for 20 or 30 milliseconds. The below ground potential spikes, to the right of the inrush peak are secondary ignition firings. The distributor cap was close to the battery cable and current clamp.
/ Starter Torque #22
I roughly calculated the area under the curves in all these three graphs and found all areas are more or less same, meaning that total energy to start the engine is more or less same for all these three engines. Peak energy level can be higher at first (big 6 cyl.) engine, but it's application duration is shorter than the others. You have the data (coordinates of the curve) - so, you can calculate the areas under the curves at your computer easily. Maybe, my rough calculation was very rough and computer integration may give a very different result and those areas under the curves are very different. Also, I am wondering how you are comparing the starter motors of different engines with different sizes, stroke lengths and volumes. What's your dimensionless parameter that makes you think that waveforms of 6 cyl. diesel engine and same cyl. same volume gasoline engine would be much different and that the diesel would absorb more energy than the gasoline during the starting periods? I mean I am just wondering how you arrived at such a conclusion from these graphs that the diesel motor is spending more energy?
/ Starter Torque #23
</font><font color="blue" class="small">( I roughly calculated the area under the curves in all these three graphs and found all areas are more or less same, meaning that total energy to start the engine is more or less same for all these three engines )</font>
</font><font color="blue" class="small">( I am just wondering how you arrived at such a conclusion from these graphs that the diesel motor is spending more energy? )</font>
First.. I -havn't- done any calculations based on the data. However.. you yourself in the first line stated that you had.. lets go with that for conversation sake.
What that means is: the small diesel and big gas both consumed the same power to start.
What can we infer from that: that CI per CI .. the diesel needs more power to start. As it took the same power to start a small CI diesel compaired to a larger CI gas. Thus a diesel the same ci as that big 6cyl gas should take more power to start than the 6cyl gas.. assuming equal ci...
Again.. I made no calc's.. just using what you have stated. Seems your first line provides the basis against the argument/question in your last line... In other words.. you answered your own question..
Soundguy
/ Starter Torque #24
Well... I can say nothing. You are right;)
Congrads and thanks.
/ Starter Torque
I always knew there were experts on this board. Now I know for sure. Thanks for all the inputs. I'll send this link to my son and he'll still say he is right. Take care and fine job.....
John
/ Starter Torque #26
I'm glad that Soundguy picked up on the subtlety - he is sharp. Here is another waveform from a 1998 Honda Accord, 6 cyl, 2997cc engine. The compression ratio is 9.4:1. I was not sure about posting it because the battery is the original and is at least 5 years old. The Accord engine still starts very quickly. The inrush current was 712 amps and it's duration was 50 or so milliseconds. We use synthetic oil in the Accord and tractor. The F150 and Civic gets the same dino oil.
/ Starter Torque #27
I don't use my Stewart Warner compression gauge very much anymore when testing cylinder compression. It's easier to perform a relative compression test with a lab scope and a quality current clamp. You disable the fuel pump or trip the inertia switch, trigger off the #1 cylinder and observe the starter current waveform. The starter current waveform displays each cylinders compression peaks and dips. Notches in the waveform usually indicate valve problems. A lower peak relative to the other peaks usually means worn rings in that cylinder. A relative compression test is not an absolute, but it's a good starting point.
/ Starter Torque #28
</font><font color="blue" class="small">( I'm glad that Soundguy picked up on the subtlety. )</font>
Well.. I try.
If you ask my frioends.. they'll probably say I'm very trying! /forums/images/graemlins/shocked.gif
Soundguy
/ Starter Torque #29
Now, a new question arised and that may make us re-think everythings in this thread.
Here are the engines I put under consideration:
1) 1998 Honda Accord, 6 cyl, 2997cc engine, compression ratio is 9.4:1.
2) 1991 Honda Civic, 4 cylinder, 1493cc engine, compression ratio is approximately 9:1.
Engine (1) is bigger than (2) as seen above. But their waveforms are showing that bigger engine (1) is spending less energy than the smaller (2) to start. So?
/ Starter Torque #30
</font><font color="blue" class="small">( Now, a new question arised and that may make us re-think everythings in this thread.)</font>
This not what I would call a rigorous experiment. There are other
sources of rotational resistance seen by the starter such as
alternator, water pump, cooling fan, and whatever mass is engaged
to the flywheel -- most of which present both inertial and
continuous loads. It is unlikely they are identical in the above three
cases. Additionally there is no way to guarantee the horizontal
width of each curve (starter engagement time) was the ideal of
being minimally sufficient to start each engine. The area under each
curve corresponds to the energy consumed by the starter without
differentiating between the percentage transformed to rotary
motion vs. heat (ie: starter efficiency) which are also unlikely to be
identical.
The other issue to keep in perspective is the inability to draw a
conclusion from effectively three data points taken at random.
/ Starter Torque #31
It's gotta be the varying frictional coefficent of different metal chrystalline lattice form contact boundary layers subjected to thermodynamic pressure that make the difference Nomad. /forums/images/graemlins/tongue.gif
Egon
/ Starter Torque #32
Change youir name to SPEEDY! That's EXACTLY what I wuz gonna say! /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gifBut ya beat me to it!
/ Starter Torque #33
The 4 banger might have a starter that is starting to drag. Or it might be heavily carboned up, raising it's compression ratio. Or the timing could be over advanced. Or it could have been tested hot and the 6 banger was tested cold. Or it could have a dirty battery terminal. Lots of possible reasons. /forums/images/graemlins/smile.gif
/ Starter Torque #34
This post turned out to be a conundrum. I decided to post the starter curves because there was a lot of creative engineering going on. The curves were a practical viewpoint, but the test universe was limited - I ran out of personal vehicles to test. My neighbor has a 30 something Hp diesel Lamborghini tractor that I will try to ramp the next time I see him. All engines were tested cold. Some said that more specifications should be added to the engine and/or starter. That would have taken the fun out of the post. There really does not seem to be a clear cut generalization that can be made. The more you think about the frictional and electromechanical losses, the more sources you can come up with. The inrush current of the 4 cylinder diesel seems pretty high for a 4 cylinder engine, but the test universe is just too small to generalize on. I think that all we proved is that it was to close to call. Another thing this post proved is that there are a lot of good thinkers on this site. Some may be stinkers and drinkers to.
/ Starter Torque #35
Yes, whenever Egon "drinks" he "stinks" and suddenly becomes a "good thinker" like he did above. See what he says above and try to smell the odor of his wisdom;)
/ Starter Torque
Would the difference be more noticable if we were using a hand crank between the two?? Definitely would have to feel different with the increased compression in the diesel...Just thought I'd ask......................... /forums/images/graemlins/smile.gif /forums/images/graemlins/smile.gif
/ Starter Torque #37
I've come to this thread late...but would it not be just as simple and reasonable to go back to say an old brand that had "dual" tractors? meaning, a diesel & gasser of the same model and simply compare their starters to see which is bigger?
/ Starter Torque #38
Well.. speaking of that.. on the fords.. in the late 50's you could get the 8XX series in diesel or gas.. and that is why they switched over to 12v.. for the diesel engines. 6v didn't work so well due to the amount of copper the cables needed.. as it was.. the small gas jobs on 6v used 1/0 thick as your thumb cables.
Soundguy
/ Starter Torque #39
On the IH tractors the diesel starter is at least half again as long as the gas starter. Same model and just 1 CU inch difference displacement in the diesel and gas.
/ Starter Torque #40
</font><font color="blue" class="small">( I've come to this thread late...but would it not be just as simple and reasonable to go back to say an old brand that had "dual" tractors? meaning, a diesel & gasser of the same model and simply compare their starters to see which is bigger? )</font>
Well that depends. If you are trying to answer the original question (without going back, it dealt with starter torque on a 30hp deisel vs a 6 cylinder jeep motor) then no. Comparing a 200 cu in deisel to a 200 cu in gas is not answering the question. I haven't seen anyone make the argument that a 25hp B&S is going to pull more current than a 25hp Kubota. That (or a 200 cu in gasser vs a 200 cu in diesel) is more of an apples to apples comparision on the face of it. It doesn't answer the original question.
2006 Ford F-550 Flatbed Dump Truck, VIN # 1FDAF57PX6EB82087 (A61165)
2006 Ford F-550...
2024 CATERPILLAR 68" HYD 4IN1 BUCKET (A62129)
2024 CATERPILLAR...
Paladin 544K 416 IC 105in. Dual Cylinder Hydraulic Loader Attachment (A61567)
Paladin 544K 416...
UNUSED 2026 INDUSTRIAS AMERICA 750 GAL TANK (A62130)
UNUSED 2026...
(2) 320/85R24 TIRES W/8LUG RIMS (A62130)
(2) 320/85R24...
2011 Ford F-550 4x4 Terex Hi-Ranger LT38 38ft Insulated Bucket Truck (A61568)
2011 Ford F-550...
