Starter Torque
/ Starter Torque #11
Where is the torque measured? Torque produces by the starter or on the crankshaft?
Lets apply a little math and see relitive pressure per square inch. A JD 4210 (28hp) has a displacement of 81 cu in. Thats 27 cu in per cylinder. Bore and stroke are not speced. If the bore is 3in the stroke will be 3.85in. Sounds about right for a low RPM hi torue motor. A 3in bore has a 7in surface area. At 400 psi compression that is 2800 lbs of force.
I will really guess on the 3.7l jeep. 3.7l is about 225 cu in or 37.6 cu in per cylinder. If the bore is 3.84in the stroke is 3.25in. Sounds about right for a high RPM motor. 3.84in bore has a 11.5 in surface area. At 175 psi compression that is 2025 lbs of force.
Now assuming the both have the same flywheel and starter the deisel will require more force(torque) for each compression stroke. However, the gas will require more work to be performed by the starter for each revolution of the crankshaft.
So in answer to your question.... it depends. Are we talking peak torque or average torque? Peak torque = 30hp deisel. Highest average = 3.7l gas.
/ Starter Torque
I am just talking about a three second crank of the starter. Call it average time or whatever but the diesel will still require more torque. Even if it cranked for a minute it would still have to do the same amount of work in both cases. I never saw a car with two batteries in parallel unless it was an RV with exceptional draw for accessories.......Not for starting amperage. /forums/images/graemlins/grin.gif
/ Starter Torque #13
Try the back door approach...
Pick two engines. Find the starter specs...whichever is larger/heavier/more copper mass/whatever should be an indicator of which engine requires more torque/power to turn it over. Especially if they are modern engines. Today engineers seem to build less fat into their systems...or should I say cushion/safety factor...
Symplistic approach...yes! But maybe just practical enough to settle the discussion.
And if that doesn't work, as suggested above, fall back on "father knows best..." /forums/images/graemlins/grin.gif
And if that doesn't satisfy, tell the kid to prove you wrong, since it will be a good learning experience. In writing naturally... /forums/images/graemlins/grin.gif
/ Starter Torque #14
Though I don't have the technical specs on the starters on our heavy equipment in our yard.. I can say that the starter on every one of our diesels is larger than the starter on the gas jobs. We have one large stationary gas engine for a blower/burner motor.. big huge engine.. not sure what it is.. but has 4 barrel carb.. and looks to be as big / bigger than a 500.. still has a 'normal' looking car starter.
However.. the starter on our cat 3208 engine which powers a genset.. is so big that it is a struggle for me to lift it and tote it around... go figure.. We also have a cummins industrial engine on stationary pump.. not quite as big as the 3208.. but easilly the same size as the gas job.. and its starter is inbetween.. smaller than the cat.. larger than the gm's.. but like I say.. I don't have on the paper specs.. so i don't know exactly what CID size engines I'm comparing.
Soundguy
/ Starter Torque #15
</font><font color="blue" class="small">( I am just talking about a three second crank of the starter. Call it average time or whatever but the diesel will still require more torque. Even if it cranked for a minute it would still have to do the same amount of work in both cases. I never saw a car with two batteries in parallel unless it was an RV with exceptional draw for accessories.......Not for starting amperage. /forums/images/graemlins/grin.gif )</font>
The average torque in the 3.7l engine will be more than that of a 30hp diesel. In other words, it will put more load on the battery.
On a second note you can't change the 'rules' 12 posts into the thread. Your origianal senerio was a 30hp deisel vs a 3.7l jeep V6. Changing the comarison to a 5.9l Cummings (or other LD truck deisel engine) is not the same as your original senerio.
So what is it? Do you want to compare the 30hp to the 3.7l or someother comparison?
/ Starter Torque
To get back on track the 30 HP 3 cylinder with the gas 3.7L. All the evidence so far clearly shows the diesel takes more torque to start. Thats what I'm getting out of this in a round about sort of way with everyone stating different facts. Bottom LINE. Diesel takes more torque or power to start on a three or 4 second crank of the starter. /forums/images/graemlins/confused.gif
/ Starter Torque #17
The easy way to find out would be to look up the specs on each starter motor and compare the amp draws.
/ Starter Torque #18
</font><font color="blue" class="small">( Diesel takes more torque or power (than Gasoline) to start ..)</font>
I added "than gasoline" to generalize your question because I think what your main question isn't about the figures/numbers, but a general comparison of required starting powers by "virtually identical" diesel and gasoline engines. Gasoline engine will require more power than the diesel. Why? Because reactional force against the piston during the compression process in the gasoline is higher than that of diesel. Because only air is being compressed in the diesel while in the gasoline a mixture of air and evoporized fuel is being compressed. Mizture of fuel+air has much higher theormodynamic pressure than the air in the diesel. But starting electric motors of diesel engines usually have higher powers than that of gasolines. This is because the diesel engines are heavier mechanics and in case of unsuccessfull flaming attempt at first strokes in the diesel, electric motor should still help the crankshaft turn and if this happens, mixture of diesel fuel + air will be higher pressure than the gasoline mixture.
/ Starter Torque #19
Here are a series of three, starter current waveforms that I captured this weekend. They are from two gas burners and one diesel engine. The waveforms are for relative comparisons only!!! To convert the electrical energy (Kw/time) to an instantaneous mechanical force (Foot-pounds/time) would probably be possible, but there would be too many factors and losses to consider for the results to be accurate. The equipment used was a Fluke 199 ScopeMeter and a F.W.Bell UM-7700 current clamp. The current clamp is a Hall Effect type and can measure up to 1000 AC or DC amps. Each curve was captured until the engine started and the solenoid disengaged. The vehicle batteries were in good condition and as you can see, it did not take long for each engine to start in this warm weather.
The first waveform is from a 1989 F150, 6 cylinder, 4900cc engine. The compression ratio is approximately 9:1. The inrush current exceeds 1000 amps, but only for 20 or 30 milliseconds.
/ Starter Torque #20
The second waveform is from a 2002 Kioti DK45, 4 cylinder, 2197cc engine. The compression ratio is approximately 19:1. The inrush current equals 1000 amps, but only for 50 milliseconds. The glow plugs are drawing approximately 80 amps - this is shown to the left of the inrush peak. After the engine starts the current draw returns to near zero. The little diesel engine definitely did take more current to start - the area under the curve is greater.
FORD 8630 POWERSHIFT TRACTOR (A62130)
FORD 8630...
2014 SKYTRAK 10054 TELEHANDLER (A58214)
2014 SKYTRAK 10054...
2023 GMC Sierra 1500 4x4 Crew Cab Pickup Truck (A56858)
2023 GMC Sierra...
2017 FORD F-150 FOOD TRANSPORT TRUCK (A60736)
2017 FORD F-150...
2006 INTERNATIONAL L9227(INOPERABLE) (A60736)
2006 INTERNATIONAL...
(15) Polyethylene Road Bed Protection Pads (A60463)
(15) Polyethylene...
