Starter problems
/ Starter problems #21
Where my previous post was in error, was saying that this test would eliminate a bad ground. A bad battery ground would not be eliminated, so both ends of the ground cable should be checked for good connections.
You know, I don't know why, but I thought you were trying to bypass the solenoid.:confused2: I went back and re-read your post and see clearly I was wrong. You are just making the normal low-current connection between the hot wire and solenoid that the the key normally makes. That's exactly how to hotwire the starter and what I would do.:thumbsup:
Notice in the photo below that the front side of the starter has a big lug with a hex-head and the solenoid connection is inside the booted plastic connection beside it. On the back side of the starter and almost impossible to access without removing the starter is the blue-black booted lead going from the solenoid's high current contacts to the motor. This style of starter is common on many tractors.
/ Starter problems #22
Looks like they are bound to make everything nearly impossible to work on eventually. :mad:
It was good that you made me look at my post so I could remember to say, "...be sure the tractor is not in gear when you..." ...are bypassing safety interlock switches.
/ Starter problems
Thanks
Took everybodys direction and cleaned ALL terminals I could find tied to starter/battery. It seemc to be working fine again for now.
PALLET OF MISC METAL (A63291)
PALLET OF MISC...
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A61307)
2006 Magnolia Dry...
CLARK FORKLIFT (A63291)
CLARK FORKLIFT...
2019 CATERPILLAR 259D3 SKID STEER (A64279)
2019 CATERPILLAR...
2015 Dodge Journey SXT AWD SUV (A61574)
2015 Dodge Journey...
2019 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2019 FREIGHTLINER...
