Starter not engaging on my TC29D
   / Starter not engaging on my TC29D #1
phul
Blaine
2005 New Holland TC29
Howdy folks, I am new to this forum found it while searching for an answer to my starting problem with my NH TC29D. I removed the starter because it didn't seem to be totally engaging. I placed it in a vise and activated it with jumpers. The gear seemed to be working as it should so I re-installed into the machine. I fully charged the battery and tried it again, same problem! I figure it may have to be installed just right because of the oblong holes in the starer housing must have to be just right. I tried everything leaving loose as I tighten the other, adjusted different positions in the mounting hole and had the darn thing out several times!! The starter just doesn't engage. I figured I would pose this problem to this group and maybe someone else has had the same problem. You'all are my last resort before I replace the starter. Please any info will be appreciated
   / Starter not engaging on my TC29D #2
   / Starter not engaging on my TC29D #3
Welcome to the site!! I have moved your thread to the NH forum, as suggested by another member as well. We hope you find some useful information on TractorByNet!! Good luck! :thumbsup:
   / Starter not engaging on my TC29D #4
I think the oblong holes may be your problem. I replaced my starter this past fall, the holes in the bell housing are round and a perfect fit for the bolts.
   / Starter not engaging on my TC29D #5
On your bench test, did the pinion gear extend out when you spun the starter? Does that have a mechanical solenoid - a lever that pushes the gear away from the starter housing when it gets power? Did you jumper straight to the motor lug or to the cable lug, then activate with a screwdriver or small jumper wire?
Can't quite tell what conditions you observed. I don't think the oblong holes are a short term problem.
Jim
2014 Ford Taurus AWD Sedan (A54815)
2014 Ford Taurus...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2021 Ford F-150 Ext Cab 4X4 Pickup Truck (A55852)
2021 Ford F-150...
2020 John Deer 3038E 4 x 4 Tractor w/300 E Loader, S/N 1LV3038EJKK126097, Diesel Engine, Joystick (A59076)
2020 John Deer...
2008 VIKING TRAILER 40+5 LOADER TRAILER (A58214)
2008 VIKING...
LOT: (2) Almost Full Jugs of Komatsu Coolant, (1) Almost Full Jug of Liebherr Coolant, 1/3 Barrell (A59076)
LOT: (2) Almost...
