Starter not engaging on my TC29D
   / Starter not engaging on my TC29D #1
phul
Blaine
2005 New Holland TC29
Howdy folks, I am new to this forum found it while searching for an answer to my starting problem with my NH TC29D. I removed the starter because it didn't seem to be totally engaging. I placed it in a vise and activated it with jumpers. The gear seemed to be working as it should so I re-installed into the machine. I fully charged the battery and tried it again, same problem! I figure it may have to be installed just right because of the oblong holes in the starer housing must have to be just right. I tried everything leaving loose as I tighten the other, adjusted different positions in the mounting hole and had the darn thing out several times!! The starter just doesn't engage. I figured I would pose this problem to this group and maybe someone else has had the same problem. You'all are my last resort before I replace the starter. Please any info will be appreciated
   / Starter not engaging on my TC29D #2
   / Starter not engaging on my TC29D #3
Welcome to the site!! I have moved your thread to the NH forum, as suggested by another member as well. We hope you find some useful information on TractorByNet!! Good luck! :thumbsup:
   / Starter not engaging on my TC29D #4
I think the oblong holes may be your problem. I replaced my starter this past fall, the holes in the bell housing are round and a perfect fit for the bolts.
   / Starter not engaging on my TC29D #5
On your bench test, did the pinion gear extend out when you spun the starter? Does that have a mechanical solenoid - a lever that pushes the gear away from the starter housing when it gets power? Did you jumper straight to the motor lug or to the cable lug, then activate with a screwdriver or small jumper wire?
Can't quite tell what conditions you observed. I don't think the oblong holes are a short term problem.
Jim
2013 John Deere 350G LC Hydraulic Excavator (A56857)
2013 John Deere...
UNUSED FUTURE FT-RR78 - 78" HYD ROCK RAKE (A52706)
UNUSED FUTURE...
MILITARY  BED TRUCK (A58214)
MILITARY BED...
10' CONTAINER (A52706)
2013 Cadillac SRX SUV (A56859)
2013 Cadillac SRX...
New Wolverine 72in Skid Steer Brush Cutter (A59000)
New Wolverine 72in...
