Starter Motor Bendix
/ Starter Motor Bendix #1
kenpaul
thunder bay ont canada
I just finished rebuilding the carb on an old M52 Onan in a Sears 917 something---Apparently a Canadian Model
Now my starter motor isn't engaging so I pulled the covers off to see the gear all chewed up. I ordered a new one ($125.00 Canadian) and am looking to find out if anyone has replaced the Bendix without pulling the flywheel off.
I don't have a puller and am hoping to be able to figure out how to get the gear off easily
/ Starter Motor Bendix #2
please help us understand something when you say bendix are you meaning the starter drive which is attached to starter or are you talking about the flywheel gear.
Yes it is just the gear itself!
/ Starter Motor Bendix #4
"gear"... is that the small gear on the starter or the big one around the flywheel?
It is the little gear on the end of the starter motor I tried grabbing the gear with a pair of vice grips and put a ratchet on the nut on the end but it is not giving in easily. I quit before i end up breaking something. I am hoping if i can get the gear off without having to pull off the flywheel .Fingers are crossed hoping someone has done this before
/ Starter Motor Bendix #6
remove the starter... then remove the gear from the starter...
/ Starter Motor Bendix #7
I'm confused here also,
usually the gear comes new with a new starter, why do you want to remove the old chewed up one.
Take the old starter out, put in the new one.
Make sure to check your flywheel for damaged teeth.
The complete starter is running well over $300.00 for this tractor , So i will go find a flywheel puller and pull the flywheel and remove the starter when the gear gets here next week and let ya know how i made out
Thanks All.
/ Starter Motor Bendix #9
So you're saying you can't remove the starter without pulling the flywheel? That's odd. Is the bendix on the end if the starter shaft, on the side away from the starter motor? We would LOVE a pic, since we're ALL confused!
Jim
Hopefully i did this right I took a couple of pix of the flywheel and position of the starter motor The tractor is pretty much the same as a GT !8 Sears
/ Starter Motor Bendix #11
Now I see what your talking about, have you tried hitting the end gear on the starter with a hammer etc..
to push it back in or turning the flywheel to dislodge the gear.
Will the starter not come out with the gear in that position.
/ Starter Motor Bendix #12
So can you remove the starter from the engine? My guess is the bendix is jammed in the extended position, possibly can't be fixed. BUT, it should come off the starter if you have it on the bench.
I would pull the starter, remove the nuts on the end of the starter shaft with a wind wrench, and see if the Bendix just slides off. For $125 I hope you got the whole drive, not just the gear.
On the bright side, the flywheel looks salvageable.
Jim
I was hoping to get the gear off the end of the starter motor without removing the flywheel. I dont have a puller so taking off the flywheel off is a pain. I thought that if i could take the nut off the end of the starter w
Nothing is jammed just a worn out gear. Believe it or not the gear is $125.00 all by itself.
Ebay had it for $80.00 US$ which is $100.00 canadian plus shipping which is another 30.00
/ Starter Motor Bendix #14
When this happens to the Bendix on a Model A Ford I put the car in second gear and rock it from front to back... so far it has never failed...
Is there anyway for you to safely rotate/counter rotate the crank?
Looks like i am going to have to find a puller to borrow or rent , pull the flywheel and remove the starter motor
Anything on this old tractor cost serious coin so i want to be carefull not to break anything else
Engine turns over fine just worn out starer teeth not engaging to crank the flywheel anymore
/ Starter Motor Bendix #17
Ken....
I doubt you have to pull the flywheel. you should be able to pull the starter off by its self. look closely but I am sure you can... you might need the assistance of a hammer to persuade movement.
/ Starter Motor Bendix #19
by some chance can you post the part number of the part you received. looking at your picture on the left the gear is held on by a spring load you should be able to push in on the end and a pin similar to a roll pin can be pulled out and the gear assembly will come off be sure to look how the parts are lined up on the shaft there is a pattern to this. as stated before the starter can be removed without taking flywheel off i feel this has to be last extreme. also do you have the starter number for your tractor that will help alot in finding a picture of your starter
/ Starter Motor Bendix #20
if you dont have the starter number please supply me with the engine serial number and all info on the tag especially if it has a number called 'SPEC NUMBER'
