Starter DK45
/ Starter DK45 #1
Sally
Kioti DK45
I have been told that the solenoid is bad. I have also been told that a new starter will cost $300.00. The tractor has less than 100 hours turned 3yrs old in May. Does anyone have any suggestions, or has this happened to you? /forums/images/graemlins/confused.gif
/ Starter DK45 #2
Talk w Kioti customer service,dealer first, if no luck take it to a local auto electric shop, can probably repair for less than $100. keep us posted /forums/images/graemlins/grin.gif
/ Starter DK45 #3
Just the selinoid is 300 or whole new starter? How much for just the selinoid? They're easy to change.
/ Starter DK45 #4
My DK45 parts manual only shows the starter as a replacable part. Seems hard to believe you would have to replace the whole thing. If you can I would take it out/apart and clean/lubricate everything and reassemble. My thought would be that moisture has gotten inside and corroded parts. This has worked for me many times!
Good luck Dave
/ Starter DK45 #5
My vote is the local starter shop. They carry parts to fix almost anything!
Ken
/ Starter DK45
The Kioti dealer in Las Cruces, NM is the one that told me that I would have to replace the starter even though only the solenoid is bad. Also, I have been told that no one here knows how to rebuild or take apart the Kioti starter. So even though only the solenoid is bad, I have to replace the entire starter which the Kioti dealer quoted a price of $300.00 /forums/images/graemlins/frown.gif
/ Starter DK45 #7
If the starter is junk anyways, whats the harm in taking to a starter shop? If you tell them you were told no one knows how to dismantle it, they will make it their mission to find out! It can't be too unique, 300$ is about the price of any other tractor starter.
/ Starter DK45 #8
ya take it to a starter shop. It should be a Valeo Starter. It will say on the starter. Any good shop should have no problem getting a solenoid for it i wouldn't think. Couldn't hurt to try.
/ Starter DK45 #9
Sally...... If you still have no luck finding a starter soleonid let me know, i can help ya out with.
/ Starter DK45 #10
Sally,you've probably fixed it by now but,I just wanted to say that my 2002 DK40 has a Delco starter.As you may or may not know Delco is a division of GM.
Looking at the solenoid I swear I've seen it used on an auto starter,so as the others have said a local starter shop should be able to help you out.......Mike
/ Starter DK45 #11
"As you may or may not know Delco is a division of GM."
It used to be but no more. General Motors did a "spin off" several years ago that divested itself of the old Delco Remy to which you refer as well as the other component divisions.
Delco Remy then sold off a lot of it's core business (including most of their heavy duty starter line) to other companies then re-named the entire components group "Delphi" which is now the largest automotive components company in the world.
MANY of the products labeled "Delco" are produced by second rate companies (IMHO) that have no association with Delphi and NONE of them have any association with General Motors any more.
TBone
/ Starter DK45 #12
T-Bone,In spite of the spin-offs there is still an association between the parent company GM and the various others.
GM vehicles still use Delco starters,alternators,radios,etc.As well as HVAC products,not to mention American Axle products.
Probably relieves them of liability,what with all the frivolous law suits nowadays...........Mike
(APPROX.100) UNUSED KJ 10' HD GALVALUME STEEL (A62131)
(APPROX.100)...
UNUSED WOLVERINE RCR-12-84W 84" HYD ROCK RAKE (A62131)
UNUSED WOLVERINE...
ASSET DESCRIPTIONS & CONDITION (A59910)
ASSET DESCRIPTIONS...
UNUSED SDLANCH DIAMOND PLATED PLASTIC MATS (A62131)
UNUSED SDLANCH...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
UNUSED INDUSTRIAS AMERICA HYD POST PULLER (A60430)
UNUSED INDUSTRIAS...
