Starter Again.
/ Starter Again. #1
Iplayfarmer
Super Member
Idaho
Massey Ferguson 1215, Case 801B
I think I'm going to need to have my starter rebuilt again.
It did this same thing a couple of years ago... It moves real slow like the battery is dead. I've charged the battery, installed a different battery, tried to jump start it, cleaned all the cables including the ground, and still had no luck.
When this happened before I had the starter rebuilt and all was well again.
It just gripes me that I have to do this again.
/ Starter Again. #2
Check where the starter mounts to the block. DOUBLE check the cables.. both negative and positive.
2ys on a starter ain't good or normal.
Soundguy
/ Starter Again. #3
I have seen corrosion "wick" up a cable. Even though the connection is clean, the corroded cable can still cause a problem. I put all new cables on my 4320 and it is like a new tractor now.
Also, I remember an old Pete we had years ago the ?Bendix? was bent ever so slightly. You could spin it on a test bench and it worked fine, but put a load on it (like starting an big cam 400 Cummins) and it would ground out.
/ Starter Again.
Soundguy
I jumpered straight to the starter and to a solid ground on the chassis using jumper cables to test that very thing. Same result.
/ Starter Again.
I gave the starter to a buddy at work whose step dad runs a motor rebuild shop. He got back with me yesterday to tell me the rear bearing was shot. That's probably the only thing the other guy didn't replace when he did it 2 years ago.
Total bill: $28. Sure beats $600 for a new starter.
I should have it back today, in tonight, and I'll be burning diesel tomorrow morning.
/ Starter Again. #6
Good thing it didn't gall on the shaft when it siezed..
soundguy
/ Starter Again.
I installed the starter Friday night.
Wow! I'm beginning to wonder if that rear bearing had been going bad since before I got the tractor. I never remember the starter spinning the engine this fast before. Even after the previous rebuild.
1987 GMC C7000 Fire Truck, VIN # 1GDM7D1G3HV526472 (A61165)
1987 GMC C7000...
UNUSED WOLVERINE 8' FORK EXTENSIONS (A62131)
UNUSED WOLVERINE...
2000 Bobcat 863 High Flow Compact Wheel Loader Skid Steer (A59228)
2000 Bobcat 863...
2012 CATERPILLAR 316EL EXCAVATOR (A62129)
2012 CATERPILLAR...
New/Unused Landhonor 8ft x 10ft Galvanized Apex Roof Metal Shed (A61166)
New/Unused...
2006 Ford F-650 S/A Dump Truck (A61568)
2006 Ford F-650...
