Started the Mulching,,Before and After
   / Started the Mulching,,Before and After #1
Spek
Finally pulled the trigger and decided to get some mulching done....got the property lines done and started on the homesite......heres some pics.
Before
After:
Before
After:
A few more afters:
Ill post some more when its done.
   / Started the Mulching,,Before and After #2
Got any pictures of the mulcher in action? How big is the lot?
None of the mulcher in action yet....(I was staying a good ways away)...the lot is 10 acres +/-.
This was a pass or two.......the are remulching some to shred the larger stuff and increase the home/septic site....
My hope is to be able to over seed it with winter rye after they are done and next year plant grass. Not sure if I can do that right over the mulch or not....
   / Started the Mulching,,Before and After #5
Yeah, you would need to get the seed in contact with the topsoil so it will come up. If the mulch has a lot dark soil mixed in you should be ok. You can always try a small area to test the condtions.
how long can the grass seed be on the ground before getting watered?
   / Started the Mulching,,Before and After #7
I would check your local weather channel and pick a rainy forcast to seed. I've used a pto driven, 3 pt, seed spreeder for a tractor before and it made the job real easy.
   / Started the Mulching,,Before and After #8
It's hard to tell for sure without a close-up photo, but some of the trees look pretty damaged around the base. I always struggle with getting too close to trees even when I'm using my rotary cutter. I'd imagine your mulcher could easily girdle the tree and kill it. I'd imagine it is just a case of learning how close you can come to a tree and then having enough self-control to stay outside that distance. The property lines do look very nice. Anyone who has ever cleared property lines will surely appreciate the job you did. Heck, I'd bet the surveyors would be have been really happy if you had done the clearing beforehand.
   / Started the Mulching,,Before and After #9
it looks perfect to me, but maybe I am a little biased . It could of been cleaner but we were running out of time
   / Started the Mulching,,Before and After #10
Great pics!! I really enjoy those before and after shots. Now that you can get in there and mover around, it will be easy for you to maintain it and even widen it if you want at a later date.
As for the grass seed, nature sends out seeds all the time, and they can last years until the conditions are right. I'd put rye down when you're ready for it, and it will sprout a few days after your next rain. The stuff to be careful with is hulled bermuday. If you spread un hulled, it will sit and wait until conditions are right, but hulled needs to be planted just before a rain as it will rot and die fairly quickly without the hull on it to protect it.
Eddie
2016 Chrysler 300s Sedan (A51694)
2016 Chrysler 300s...
2025 K4525 UNUSED Double Garage Steel Barn (A53117)
2025 K4525 UNUSED...
UNUSED FUTURE HYD WOOD DRILL (A51248)
UNUSED FUTURE HYD...
2019 Ford Explorer SUV (A51694)
2019 Ford Explorer...
UNUSED INDUSTRIAS AMERICA F10 HYD LAND LEVELER (A51247)
UNUSED INDUSTRIAS...
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
