Start problem Case IH 275 compact
/ Start problem Case IH 275 compact #1
reloader-51
MF255
Hi all. Need some help with my 275. Turn key to heat, wait 10 seconds and doesn’t do anything. Can turn key on and jumper from solenoid to starter and starts right up. Have installed new ignition switch, new battery,new cables, jumpered safeties, new starter/solenoid. Any thoughts? Thanks!
/ Start problem Case IH 275 compact #2
That must be a B 275 ?
/ Start problem Case IH 275 compact #3
It sounds like you've overlooked one of the safeties or one of your jumpers is incorrect or not making contact. Note that some safety switches open when activated. You need to understand what the switch is doing and how it works.
/ Start problem Case IH 275 compact #5
I have a 255 and I am currently trying to change the battery. There must be an easy way to remove the hood with a loader frame installed, but I can't find it. The thing worked until it put it into the shop to replace the ground cable from the battery. Now it won't start; in fact when I short the solenoid the starter spins wildly but will not engage.
2015 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A61573)
2015 Chevrolet...
WoodMaxx MX 9900 with almost no use
WoodMaxx MX 9900...
2025 IREV Electric Scooter (A64194)
2025 IREV Electric...
GYRO TRAC GT-25 FORESTRY MULCHER (A65053)
GYRO TRAC GT-25...
JOHN DEERE 467 ROUND BALER (A64278)
JOHN DEERE 467...
2012 18ft Gastron Boat with 18ft Magic S/A Boat Trailer. (A64557)
2012 18ft Gastron...
