Starship News
/ Starship News #161
Starship scheduled for the 4th flight did a full throttle test burn on March 25. Booster still needs to be moved to launch pad for it's testing. They found some burned cryogenic delivery lines on the launch pad that need to be repaired/replaced before any testing of the booster can happen. SpaceX hoping for early May launch for flight test 4.
/ Starship News #162
The Starship Booster was moved to the launch pad on Thursday April 4th, and a static fire test of the engines was done on Friday the 5th. Still hoping for early May launch date.
/ Starship News #163
Looks like Starship 4 and booster 11 were moved to their maintenance buildings a few weeks ago. Starship 5 was moved to launch pad to test fire the 6 engines a few days ago.
Starship 4/Booster 11 are waiting for FAA to finish evaluation/report on Starship 3 flight before granting license for Starship 4 flight.
/ Starship News #164
Booster 11 was moved back to the launch pad on Saturday. Assumption was for more testing. I saw a footnote that said that SpaceX has a license for Starship 4 flight, but SpaceX wants a modification to the license and that is what they are waiting for. Musk posted on X that he thinks Starship 4 launch is 3-5 weeks out.
/ Starship News #165
Jim, are you a member of the NSF Forums?
/ Starship News #167
On Wed, the 15th, the ship was stacked on top of the booster at the launch site. They are still talking 3-5 weeks before launch as the requested license modifications have not been approved yet.
/ Starship News #168
On Monday, the 20th, they loaded the ship and booster with a total of 10 millions lbs of propellant as part of a practice countdown. It was a successful test. Tuesday they removed the propellant, removed the ship from the booster and put it back in the maintenance hanger. They are still installing the heat shield tiles. Key deliverable for this flight is successful reentry/splashdown for both the booster and the ship. They are not planning on relighting the engines or anything else they did on launch 3. Musk tweeted today that ship 4 should launch in about 2 weeks. Although they are still waiting for FAA approval.
/ Starship News #169
Starship flight 4 has a penciled in launch time/date of 08:00 EDT June 5. This is dependent on getting the FAA approval in time. Issues with flight 3, both booster and the ship, are reported to be centered around dirt in O2 tanks and not enough filtration causing nozzles to get plugged and then the engines and thrusters to not re-ignite when needed.
/ Starship News #170
According to SpaceFlightNow.com, Starship 4 launch has been moved to NET June 6 08:00EDT.
No reason given for the one day delay.
FAA has told SpaceX they can launch Starship 4 without completing the Starship 3 investigation, but it is unclear if the FAA has signed off on the launch license for Starship 4.
NET= Not Earlier Than
/ Starship News
It looked like we might have a dual launch on the 5th at one point, with Starship and Starliner.
Interesting space launch days ahead for sure.
China just landed on the moon and acquired samples which are already on their way back to earth..
America needs to step up our game thank goodness for SpaceX.
/ Starship News
SpaceX will offer a free live webcast of the Starship Flight 4 launch beginning at about 7:30 a.m. EDT (1130 GMT). You can watch the livestream here at Space.com, courtesy of SpaceX.
/ Starship News
Looking great so far
boost back successful with soft water landing of the booster.
Starship is on trajectory coasting for landing burn upcoming to soft land in Indian Ocean.
Major improvement from last launch so far.
They burned a flap on descent but had video some of the landing water landing engine firing was successful.
A great job SpaceX.
/ Starship News #175
Starship 5 launch to be near the end of July. FAA says none of the issues with Starship 4 flight will require investigation. For flight 5 booster landing, Musk says he is planning on "capturing" the booster at the launch pad and believes that will require a new license approval. Lots of work to be done regarding the heat shield tiles and the heat shields for the 'flaps' before next launch. Work being done on the second launch pad at Boca Chica. There is also going to be 2 launch pads in Florida. Plan being one for launching, one for 'catching'. It was also noted that 1 of the 13 engines firing during 'boost back' to slow the decent of the booster in prep for 'landing' in the ocean, blew up shortly after re-ignition. No word yet as to why. It was noted that the hold down clamps at the launch pad were being removed, again, no word as to why.
/ Starship News
New Interview with the Everyday astronaut and Elon at Starbase and the future :
/ Starship News #178
Starship is still not available in my area. I signed up to upgrade my HughesNet equipment. They are using a new satellite - Jupiter. I will soon see if it's that much better. Upgrade installation will be done on - 6/29/24.
/ Starship News
Oosik type in your address in the service box shown in the first link .
It will tell you if service is available at your address
All of eastern Washington has Starlink service available unless I am missing something.
Starlink is unlimited Data and most days our download speeds are over 100Mbs with 20ms latency.
Hughesnet will never match the latency, because of using geostationary satellites
Starship is the new reusable Rocket SpaceX is testing
/ Starship News #180
sd55dan - I just did that. I guess it IS available now. They didn't say yes or no. They listed the price. The monthly cost is about $60/month more that I will be paying for the new HughesNet Jupiter system.
DRAGON 500 BBL FRAC TANK (A67714)
DRAGON 500 BBL...
2022 JCB 509-42 TELESCOPIC FORKLIFT (A65053)
2022 JCB 509-42...
7ft Fork Extensions (A66734)
7ft Fork...
Shop Tool Box (A64912)
2015 PETERBILT 320 6X4 T/A CNG GARBAGE TRUCK (A66091)
2015 PETERBILT 320...
CAT D5 Rear Screen (A68134)
CAT D5 Rear Screen...
