Starlink
/ Starlink #1,601
Spent some time looking into a mesh system, so far all that I have seen require a WAN connection. My Verizon LTE box doesn't have an Ethernet port so I can't connect to the WAN port on the mesh system. Unless I am missing something.
As noted, a wifi repeater with an ethernet jack could work for that. Defeats some of the benefits of a mesh system to have to use that, but if that's the only way at least it would still spread out decent wifi signal throughout the house and still be a better connection than weak wifi from the LTE modem in distant parts of the house.
Or check into other LTE modems. For instance, on the LTE Internet plan I have with AT&T it came with a Mobley device but I swapped it for a Netgear Nighthawk M1, which is much faster (four radios instead of 1) and does have an ethernet port.
For instance, this one:
Verizon themselves may sell an upgraded modem with the features you need.
Does your Verizon LTE modem have a USB WAN output. The Mobley did, which is how I connected it to my router when I used that device.
Rob
/ Starlink #1,602
Rob
The only port on my V LTE modem is for its power.
I'm considering this unit,
Should kill two birds with one stone, so to speak. If it doesn't cover the whole house, it has a port I can use to connect to a mesh system. Although I might have a little trouble getting it to pass the WAF.
/ Starlink #1,603
Likely for cost reasons and the fact that most devices out there are wifi capable these days so they go with the 'works for majority' situation.
I get that. I've noticed that very few laptops today have ethernet jacks on them, in the interest of making them very thin, sheesh many of them don't even have the large USB jacks on them anymore either just some mini-plug. I'm guessing on these that when the battery goes, it's not easily replaceable.
Maybe I'm just old school.
/ Starlink #1,604
That's because wifi has become that capable and reliable that an ethernet wired connection isn't really any better. Wifi is essentially ubiquitous and if it works well for most then the alternatives melt away, especially if they add cost or weight. The USB situation you mention is because USB-A (the normal port on a computer since forever ago) has been replaced by the new USB-C standard. That's the smaller version you've seen. There are adapters and hubs to allow older USB-A stuff to connect to USB-C.
It's the same reason we don't see many optical drives any longer and the floppy has been gone for forever. New stuff is better and takes over. With the advent of wifi mesh systems I don't see wired ethernet continuing to be around much longer at all for home use. 5-7 years ago if I were to build a home I'd have wired it up with ethernet and co-ax for network and video. Now I'd rely on wireless completely and save all that cost & complexity.
Rob
/ Starlink #1,607
Bud thats a huge stretch, for a normal user no, most won't see a difference, but to say there is no actual difference is utterly incorrect.
the fastest i have ever seen wireless do is about 700mbit, that is optimal condition, which almost no one ever gets.
if i moved 1 room over its barely 200mbit. 5GHZ doesn't even work more then 2 rooms away in my house, 2.4 still is the main transport in my house, and I am the only one for miles. 5ghz simply doesn't go through my walls. This was after doing a wifi audit of the house for finding best placement.
my house i rewired for ethernet, I routinely saturate 1gb with various tasks. it also isn't affected by walking 3 feet to the right.
95% of the wifi i deal with or use, can barely break 100mbit let alone 1g. wifi still kind of blows for VOIP as well.
/ Starlink #1,610
Yes, WiFi has come a long ways, and is usually sufficient for homes and businesses that don't have high data demands.
Most wifi is capable of WAY more speed than anyone's actual ISP connection speed. Except the folks that are lucky enough to get Gb ISP connections.
/ Starlink #1,611
Most folks I know in the corporate IT world work on wifi, whether in the office or when they are WFH. The percentage of people who *need* connections more than like 20 Mb/s to do normal jobs or anything at home is small. 200 Mb/s is monstrous, especially since you're posting this in a thread about Starlink, which is a ISP offering aimed at rural users who have very, very low average speeds compared to city dwellers.
My comment was about the fact that *most* users work just as well on wifi as ethernet and I stand by that. Sure, there are special cases out there but the percentage of folks who would find a decent wifi connection (paired with an ISP that exceeds the speed a decent wifi connection supports) is tiny. You can find edge cases to contradict me on but that's not the norm.
Rob
/ Starlink #1,612
Rob
I'd say for what i've seen, most can use WiFi just fine, assuming good coverage, but the key thing, is good WiFi coverage.
/ Starlink #1,614
Yeah, I don't miss floppies at all, and CD-Rs very little. About the only thing I use the CD drive in my PC for these days is ripping songs from CDs to digital files. Haven't used them as archives in probably 10 years. Flash drives or a NAS are so much better for that!
/ Starlink #1,615
Just inquired about Starlink service, as a "new customer" using a nearby address:
CA- Starlink is currently at capacity in your area, so your order may not be fulfilled until 2023 or later. You will receive a notification once your Starlink is ready to ship.
NV- Starlink expects to expand service in your area by late 2022 to early 2023. You will receive a notification once your Starlink is ready to ship.
I think this is the first time I have seen the "its currently at capacity" message ...
/ Starlink #1,616
I had something similar when we first moved here and I tried to sign up for satellite internet (Wildblue). A couple neighbors mentioned the same thing. Not really sure what that was all about. A couple months later I got a notice that it was now available. This would have been ~ '05/06.
/ Starlink #1,617
Starlink breaks up geography into hexagonal cells of about 13 mile diameter. They have some max capacity within each cell. They may have changed the message but this has basically been what they have been saying all year when a person inquires and their cell is 'full'.
Rob
/ Starlink #1,618
Finally got an email from Starlink, not what I was hoping for. Went from mid to late 2021 to mid 2022.
/ Starlink #1,619
No email from Starlink, but I just checked my account and as of this morning it was showing MTL '21, this evening it is showing March '22.
/ Starlink #1,620
3145 (A63117)
3145 (A63117)
7' Pallet Fork Extensions  (A62679)
7' Pallet Fork...
1999 38ft Beverage Trailer (A65563)
1999 38ft Beverage...
Steel Wheelbarrow (A65640)
Steel Wheelbarrow...
2019 HAMM HD+140IVV DOUBLE DRUM ROLLER (A65053)
2019 HAMM...
New/Unused CFG Industrial MX12RX Mini Excavator (A65579)
New/Unused CFG...
