Starlink
/ Starlink #1,381
What part of PA do you live in and when did you get your starlink. I'm in west central PA and waiting. Have not seen many from PA that have gotten starlink.
i do not currently have it. but i put in for it. and was granted access about 3 months ago. I live near Scranton PA.
/ Starlink #1,382
Off topic, but can't resist ...
I met a guy years ago who discovered that wifi router frequencies had some overlap with HAM radio frequencies. Off-the-shelf routers were limited to (I think) to 600mw, but a licensed HAM on that same frequency could legally broadcast at 50-1500 watts, i.e. 50 to 150 times the power of a stock wifi router.
He installed "Tomato" firmware on a Linksys WRT54G router, which gave him control of xmit power. He upped the power into HAM radio levels, and was getting a realiable wifi signal ... drum roll ... 10 MILES AWAY! Aaahhh. Imagine that ....
But, he quickly fried the chips/circuit board in the Linksys router at that power level. Last I knew, he had built a small radiator that sat on top of the main chip of the router-- and was pumping water through it to dissipate heat-- just like in a vehicle.
I think of him every time I hear mention of wifi performance. :LOL:
Issue here becomes the other end transmission will be too weak to be received by the router so although he sees his SSID, he can't connect to it or if he can at a closer range, it will be sporadic.
/ Starlink #1,384
North East PA still waiting too.....
I'm a little shocked you can't get it yet, your only about 20 minutes from my location.
I'm sorry maybe i was wrong. i was given a email to make a deposit, i thought that meant it was available. not sure why i would pay before its available,
but i went through it again and i can still make a deposit, but this is the message now...
"Starlink is targeting coverage in your area in mid to late 2021. You will receive a notification once your Starlink is ready to ship."
/ Starlink #1,385
I think this is fast becoming like the phrase.
The Checks in the Mail
/ Starlink #1,386
You can get surprising range out of basic legal (unamplified) WiFi. A number of people have gotten over 100 miles with standard laptop adapters on either end.
The key is focus. They basically had old school 6' satellite dishes on either end to focus signal. Radio waves are like light. If you want distance you go for a laser beam. If you want coverage you want a lantern or light bulb. Focus (gain in RF terms) works on send & receive. A directional antenna rejects signals everywhere but where it's pointing, making things quieter so you can better hear the signals you care about.
The more gain you have the more range you have but the more precisely you have to have antennas lined up. Low gain antennas are what most people want for home networks as there is 0 antenna aiming involved.
In a wardriving competition in Colorado Sorings a few years ago we identified & got GPS markers for over 80,000 WIFI networks in under 2 hours. We tagged numerous United & Southwest in- flight WiFi too.
/ Starlink #1,387
I know of people in other towns that have it, but we are still waiting. We get no cell reception at our house and have frontier who sent us a letter saying 2mbs is the absolute best you will get so stop complaining about the speed.....Starlink will be a game changer, and we just patiently wait for it.
When mounting it, are people recommending in line lighting arrestors? drip loops? just want to make sure the install is not messed up by me. lol
/ Starlink #1,388
I have a AP on my roof, i have an arrestor on it, and i drip loop everything
this is what I have
/ Starlink #1,389
Definitely yes to both.
I use surge protectors on everything, and "the more the merrier". I would recommend that you get surge protectors that have both gas tubes and TVS diodes on all lines. Clamping four out of eight lines doesn't help you much at all. I would also look for devices that have tested and claim the level of surge suppression. There is a lot of cheap junk out there. A lot.
Amazon.com: Ditek DTK-MRJPOES Power Over Ethernet Surge Protection for IP Cameras and NVRs, PoE, PoE + and Hi-PoE Compatible; Ethernet Data Speed without Signal Degradation : Electronics and
Use a heavy gauge ground wire (6ga) and if possible run it to a ground rod. (Short path) If I can, I prefer to use the surge suppressors as the cables come into the building.
If you are using POE double check that the arrest or works with POE as not all of them can handle the current.
I would regard these as disposable items.
All the best,
Peter
/ Starlink #1,390
All the best,
Peter
So you add a dedicated ground to the dish itself? I will have to pick up a ground rod, and some wire. thank you I didnt think of that.
/ Starlink #1,392
why do you have obstruction? tree/house blocking? or not enough satellites?
/ Starlink #1,393
Those images seem like you're in a browser on a desktop. How do you get to the obstruction map in a web page? I have 'Obstructions' section under 'Support' but it is just a text page that say "Not obstructed". Wonder if the map would show up only if there are some obstructions?
Rob
/ Starlink #1,396
are you really dropping internet every 20 minutes?
Not as far as i can tell. I'm not doing any network apps or protocols that are sensitive to disconnects though. Mostly streaming, web pages. Actually i'm kind of tickled it's around 20 minutes. When i used the phone app, best i could get was 4 minutes, but i'd heard other people say they were just fine with similar results from the phone app. I'm not keen on dropping any of the trees the app's complaining about, too close and too tall for someone with my meager skills with a chainsaw. I'm sure my home insurance would be unhappy if i tried. If they were further away, i'd not have a problem sawing them down, but then i probably wouldn't need to remove them anyway, and i still have a large amount of wood to process into firewood.
I should add, i did get a short period, 2 second, lag when posting this before editing with this last comment. But compared to what what i'm used to with my other Internet provider, it seems instantaneous. My prior speeds would go from less than 1Mb to 2Mb at times. 2Mb was pretty rare though.
/ Starlink #1,397
what speeds are you typically seeing? and yes without the apps, most people would never notice. you could do a basic pingplotter software if you cared enough, or setup something like PRTG if you really care... etc.
/ Starlink #1,400
It varies, not surprisingly, but seems to average between just over 100Mb to 200Mb download speed, at around 20-30ms. I might think about doing something with PRTG or something similar on docker running on a vm, but have some other things taking up my time right now.
T/A CO2 Tanker Trailer (A64194)
T/A CO2 Tanker...
213141 (A64276)
213141 (A64276)
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
TAYLOR S/A LOOSE LEAF TRAILER (A64278)
TAYLOR S/A LOOSE...
2016 Ford F-650 18ft Hydraulic Dovetail Hauler Truck (A61573)
2016 Ford F-650...
2017 FREIGHTLINER CASCADIA 125 6X4 T/A SLEEPER TRUCK TRACTOR (A67147)
2017 FREIGHTLINER...
