Starlink
/ Starlink #3,361
Also, you can just unplug the cable to the dishy at the AP end. So unless something comes loose up top there would be no need to get up there.
I do agree with not crawling on the roof if you don't have to though. Not sure how ill mess with antenna on my 60' HAM radio tower now that my neighbor sold his 60' man lift. I could climb the tower, but really don't want to (and don't have the proper harnesses).
Harnesses and safety lines are cheap in comparison to a fall, at least in my book. I find heights more challenging psychologically today than when I was younger for some reason.
Could you rent a man lift from your local rental store?
All the best,
Peter
/ Starlink #3,362
All the best,
Peter
I'll definitely be doing it in a safe manner. I just have no immediate need. If I were to have sn immediate need I'm sure I could find a man lift. With my back these days I'd likely hire a climber with the right gear than get the right gear & do it myself.
I believe in having the right toys & being self sufficient. But on some things the effort to properly train & equip myself for very occasional usage isn't worth it. Human life rated carabiner fail very easily if side loaded, ropes are only rated for a few years & a pile of other considerations I don't want to try & memorize.
/ Starlink #3,363
Site Inspector showed up.
She was there chicken out my installation. . .
/ Starlink #3,364
Dude cuts the bottom of his dishy off, hard flat mounts it to the top of his overlander camper rig. Then cuts the cable & powers it with a DC POE injector running off automotive 12v instead of A/C. It sounds like it worked out well. Not sure if i'll go that far, but could see going that down that path partially on my RV trailer. Trailer gets parked next to the house, so it could serve the house too. May need to plug Ethernet into the trailer as WiFi might be a bit iffy through several walls & across the house.
/ Starlink #3,365
Antenna is up!
router is plugged in.
took before and after photos - tried to get video of Dishy moving but by the time I got upstairs and the tablet cam brought up it stopped moving. OF COURSE. . .
Waiting on setup to finish. . .
Before power up (looking south):
After it stopped (and before I could get video):
And current position:
/ Starlink #3,367
And some more photos:
Mrs was on belay:
and a successful lift:
550 Paracord makes good temporary guys, and 1/8” coated steel makes better guys:
view from the far edge of the lot, up on the slope.
it gives a good idea why this needed to be on a mast,
And this is why I need scaffolding to mount it on the house
And it is so nice that photos are uploading to TBN in under three second - normally this entire post would be the upload length of one photo posting!
/ Starlink #3,368
And now my first post that is not on crappy DSL!
(y)(y):D Congratulations!!! Give it 24 hrs or so and then look at the app and see what your obstructions look like. It will also update the router and the dishy firmware in the next few days, most see an improvement after that happens.
Love it when a plan comes together!!
/ Starlink #3,369
Thank you! I hope the pictures make my ramblings of the last several days make more sense 🤣😂
/ Starlink #3,370
Side by side comparison from about an hour ago:
2019 Ford Transit 250 Cargo Van (A59230)
2019 Ford Transit...
2019 Dodge Grand Caravan Van (A59231)
2019 Dodge Grand...
2012 Range Rover SUV (A59231)
2012 Range Rover...
159120 (A60430)
159120 (A60430)
2018 FORREST RIVER WILDCAT BUMPER PULL (A60736)
2018 FORREST RIVER...
2005 SHOP MADE MANIFOLD TRAILER (A60736)
2005 SHOP MADE...
