Starlink
/ Starlink #3,311
I'm in Virginia and I am routed thru the POP in New York. I find if I use Speediest.net to check my speeds, there is a lot of variation depending on which server I am connected to. It was even worse when I was connected to the Atlanta POP.
How can you tell where it is routed?
/ Starlink #3,312
I got that offer and looked and thought about it. As even with zero obstructions our connection speed is not as good as most people talk about.
I'm under 100 Mb down and 10 Mb up often.
This morning 59 Mbps on the first speed test and 77 Mbps in the second test, 12 -19 Mbps uploads.
So nothing like most people brag about but much better then my previous line of sight radio link.
I wonder if my low speeds are a result of congestion at the ground station my system links to, it's New York City and I already know that not much good ever comes out of there.
It's not clear from the Starlink e-mail whether or not there is a significant improvement in speeds with the High Performance equipment. The main focus seems to be improved functionality in cold weather. $1900 is a mighty expensive defroster.
/ Starlink #3,313
I was wondering of data transmission up and down was improved with the business upgrade or is the data quantity just raised?
/ Starlink #3,314
If you go to Starlink.sx and put in your location it will show you your POP site, as well as what satellites you should be connected to. It is not the most intuitive process to enter your location though. The other thing is if you go to Speedtest.net to run a speed check, before you hit the GO button, just below and to the right of the GO button it will tell you the POP. For me it is: New York, NY.
/ Starlink #3,315
An even simpler way is what locations do the various chain stores throw at you as a default location.
/ Starlink #3,316
I just came across this thread. I usually only do tractor stuff on this site - I never noticed this Rural Living forum....
Specifically to this topic we have had SL for around 2 years. It was just just-in-time because we are off grid with zero utilities and when 3g was discontinued it killed our only cell reception that we only got that with a booster mounted high above the roof. And with that you rarely have a conversation without it dropping. I.E., its hard to boost a signal that's barely there.
So SL went in before the 3g ended, TG. We dialed in the phones for WiFi calling via SL. Now if the call drops its usually on the other end. And HD calls. And push the button we have a HD call and video to see the caller, etc. It has been a game changer for us. In a rural area I have never have bandwidth like this. Due to habit, we never really use it either other than the obvious. Once in a while we may stream a movie. There is no such think as streaming in the background a not using it or paying attention - it's like leaving your faucet running and going to town.
I'm not going through 330+ pages of posts for things I could help with....
/ Starlink #3,317
I purchased a Starlink Mesh Router and, though it works, am a bit dissatisfied with it. My primary Starlink router is in an upstairs room and I placed the Mesh Router in a downstairs room on the other end of the (small) cabin. My mesh router says its signal is 40%.
I expected much more as I had no trouble using a computer or my phone where/before I put the mesh router in. Perhaps it needs a bit of time to sync. Time will tell.
/ Starlink #3,318
The intent of a mesh network is that mesh nodes are spread out across the building but each node is close enough to another for strong signal, which it then relays on to the next node by distance. If you just have a single mesh node and place it far enough from the main router to only get 40% signal then it really isn't an optimal arrangement. You may want to purchase another mesh node or two. Or return the SL mesh and buy a different brand's mesh system, which would include 3+ nodes by default and probably cost less.
/ Starlink #3,319
Try putting the Mesh Router closer to the Starlink router. I think it should work better if you get it's signal percentage higher. Typically with WiFi, the lower the signal strength, the slower the speed.
I am curios why you bought one if you didn't have a problem to begin with?
/ Starlink #3,320
Understood. However, I expected a bit more range. The Starlink is installed in a small cabin with a loft. I added a garage to the cabin. The Starlink router is upstairs on the South End of the building. I put the mesh on the North end of the 1st floor. Besides the vertical, I expect they are about 30' apart. Total distance might be 36'. The wall and ceiling between them is standard construction. Should I expect to have to put a mesh closer than every 36'? Perhaps I should return the SL and go with another system.
HYDRAULIC TILTING BUCKET FOR MINI EXCAVATOR (A58214)
HYDRAULIC TILTING...
KUBOTA SVL75-2 SKID STEER (A62129)
KUBOTA SVL75-2...
Groundsmaster 3500-D madel 30839 (A56859)
Groundsmaster...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2011 HEIL TRAILER INTERNATIONAL CRUDE TRAILER (A60736)
2011 HEIL TRAILER...
HYSTER S50FT STRAIGHT MAST FORKLIFT (A59823)
HYSTER S50FT...
