Starlink
/ Starlink #2,582
To me the good news is that there aren't a bunch of errors in your log, the ping flood didn't lose many (21 packets), and the ping times look ok, but not great. I would have expected ping times closer to 1-2ms, or below, rather than 4.3ms. And it doesn't seem to be a Starlink issue.
Questions:
Have you tried reseating, unplugging and plugging back in, all the Ethernet cables, checking for dirt/debris with a bright light, or some compressed air? I would double check your crimps, just in case. as I am sure you know a single intermittent contact can cause all sorts of issues.
On your particular network, under Networks, usually Default, is the purpose corporate and the network group LAN, I.e. default?
The network range should be 192.168.10.1/24, that should generate 254 addresses. You might try clicking the update DHCP range button. I am a bit puzzled as to why DHCP should start at .6; what is the netmask set to? (e.g.255.255.?.?) I think that it should be 255.255.255.0 Can you test DHCP Server to on DHCP name server to auto, and DHCP gateway IP to auto? Do you have the advanced options off, including IPV6 to off?
Sorry not to have the answer. I will noodle some more on this.
All the best,
Peter
/ Starlink #2,583
Questions:
I ran the cable out to Dishy through a 3/4" length of PVC and it was a tight squeeze. The connector on the cable was covered in tape to keep it clean, but I had to pull pretty hard to get it through. That could very well have damaged the cable. I'm scheduled to have a trencher on site sometime soon, and plan to trench and run a larger conduit for a longer, 175' Dishy cable. Maybe that'll make a difference, but since the bottleneck seems to be between the Unify system and the SL router, I'm not expecting much improvement.
The Ethernet connectors Ubiquity sells are clear plastic, and I check each crimp under high magnification to make sure the wires are fully seated and there are no stray "hairs" shorting out adjacent connections. Yeah, been burned by bad connectors before...
Didn't have a corporate option until I switched back to the Legacy Network interface, but once there, both corporate and network group LAN were there. Another instance where the new interface just can't get the job done, yet Unifi keeps pushing it on their users.
The Gateway IP/subnet is 192.168.10.1/24, network range is 192.168.10.1 - 192.168.10.254, and network IP count is 254.
I can't find it in the legacy interface Network -> Networks. Don't see it in the new interface, either. Where is that button?
That's something I picked up from a CrossTalk Solutions video. Forget the reason he sets his up that way, though.
Confirmed: netmask is 255.255.255.0.
DHCP Name Server and DHCP Gateway IP are both set to auto.
No advanced options are enabled, no IPV6.
I've been wanting to try putting the SL router into bypass mode, but couldn't get past the login in the SL app. I tried one more time today, this time punching in my username/password instead of using a password manager. And I got in. WTF?
Anyway, with the SL router in bypass mode, I used Ookla Speedtest on the MBPro to run another set of tests.
Down Up
50.8 13.2
38.4 6.58
53.1 6.07
52.4 7.16
38.6 7.48
___________
46.7 8.10
Since the SL router is in bypass mode, there's no SL WiFi network, but I can still use the SL app on the iPhone ti speed test through the Unifi WiFi:
Down Up
34 7
44 5
63 14
43 12
63 10
___________
49.4 10
Pretty much the same.
I also notice that now on the Unifi Network -> Dashboard, WAN1 reports an external IP of 100.101.101.194. Before, I was getting an IP in the 192.168.X.X range.
Another oddity is that the StarLink app on the phone is reporting obstructions, but none are visible in the VISIBILITY page of the app.
Again, thanks for the help. If you come up with any other ideas, lemme know.
Until then, maybe we should return this thread to the regularly scheduled programming...
/ Starlink #2,584
you may want to check you unifi bandwidth (20/40/80) etc... and the band. sounds like you might be on 2.4/20
my unifi pro, can do 600mbit on 80/5.8 via lan transfer etc...
/ Starlink #2,585
Dishy runs on the 100. network, so that's why the address shifted. No worries.
Ethernet isn't fiber, but yes, it doesn't respond well to being pulled hard.
Have you tried using your other WAN port to see if the behavior is any different?
It is to the right of the network address in the old interface IIRC. But your network addressing seems ok.
Can you plug your MBP into the bypassed Starlink router at the Ethernet adapter and run a speed test? (I.e. Cut out your beautifully made Ethernet cable and the whole UDM-PRO?
All the best,
Peter
/ Starlink #2,586
Somewhere in this mess is the WiFi network in use. I think it's the first Gunsmoke listed. That's the only one that lists a Transmit Rate...
Software Versions:
CoreWLAN: 13.0 (1375.2)
CoreWLANKit: 13.0 (1375.2)
Menu Extra: 13.0 (1380.2)
System Information: 12.0 (1300.2)
IO80211 Family: 12.0 (1200.12.2)
Diagnostics: 1.0 (805)
AirPort Utility: 6.3.9 (639.9)
Interfaces:
en0:
Card Type: AirPort Extreme (0x14E4, 0x7BF)
Firmware Version: wl0: Oct 23 2019 08:32:36 version 9.137.11.0.32.6.36 FWID 01-671ec60c
MAC Address: f0:18:98:99:68:56
Locale: FCC
Country Code: X0
Supported PHY Modes: 802.11 a/b/g/n/ac
Supported Channels: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 36, 40, 44, 48, 52, 56, 60, 64, 100, 104, 108, 112, 116, 120, 124, 128, 132, 136, 140, 144, 149, 153, 157, 161, 165
Wake On Wireless: Supported
AirDrop: Supported
AirDrop Channel: 0
Auto Unlock: Supported
Status: Connected
Current Network Information:
Gunsmoke:
PHY Mode: 802.11ac
BSSID: e0:63:da:78:5d:47
Channel: 36,1
Country Code: X0
Network Type: Infrastructure
Security: WPA2 Personal
Signal / Noise: -65 dBm / -95 dBm
Transmit Rate: 180
MCS Index: 0
Other Local Wi-Fi Networks:
Gunsmoke:
PHY Mode: 802.11n
BSSID: e0:63:da:77:5b:d7
Channel: 6
Signal / Noise: -77 dBm / -95 dBm
Gunsmoke:
PHY Mode: 802.11n
BSSID: e0:63:da:77:5d:47
Channel: 6
Signal / Noise: -58 dBm / -95 dBm
Gunsmoke2.4:
PHY Mode: 802.11n
BSSID: ee:63:da:77:5b:d7
Channel: 6
Gunsmoke2.4:
PHY Mode: 802.11n
BSSID: ee:63:da:77:5d:47
Channel: 6
Signal / Noise: -59 dBm / -95 dBm
GunsmokeGuest:
PHY Mode: 802.11n
BSSID: e6:63:da:78:5d:47
Channel: 36,+1
Gunsmoke_IoT:
PHY Mode: 802.11n
BSSID: ea:63:da:77:5b:d7
Channel: 6
Signal / Noise: -76 dBm / -95 dBm
Gunsmoke_IoT:
PHY Mode: 802.11n
BSSID: ea:63:da:77:5d:47
Channel: 6
Signal / Noise: -56 dBm / -95 dBm
/ Starlink #2,588
First one says current, then there are the others.
/ Starlink #2,589
The BSSID looks like MAC addresses, from same brand of equipment.
/ Starlink #2,590
@RedNeckGeek You might want to check that your access points aren't putting you on your presumably bandwidth throttled guest network. I.e. try deleting all of the WiFi authorizations except for Gunsmoke 5GHz on a single device, e.g. a tablet, and rerunning the speed test.
All the best,
Peter
2014 18ft. Parker Performance T/A Trash Trailer (A60352)
2014 18ft. Parker...
ALLMAND LIGHT TOWER (A60736)
ALLMAND LIGHT...
KUBOTA M6S-111 TRACTOR (A59823)
KUBOTA M6S-111...
New Holland EC215 (A60462)
New Holland EC215...
Hay Spear (A60463)
Hay Spear (A60463)
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A61307)
Neckover GL24-2-7K...
