Standby Generator - Diesel or NG?
   / Standby Generator - Diesel or NG? #51
He must if he needs a 40KW genset:) Actually the ammount of glass dosn't really effect how much peak load he has, it just means that those peak loads involved with the heating and cooling run longer to make up for the energy lost out thru those windows. So he will burn more fuel keeping the temp at a particular level, than an equally sized structure with less glass.
I don't think this is your typical household. IMO I think he needs an actual-use energy study to properly size his generator. Then again, when you are talking about the money involved with even owning a structure this size, perhaps the cost difference between installing and operating a 20KW set vis a 40KW set might not even be worth the thought.
   / Standby Generator - Diesel or NG? #52
kenmac said:
The nat gas never down. Most nat gas pumping stations (around here ) have back up power
Because their backups run on NG!! :D
   / Standby Generator - Diesel or NG? #53
MtnViewRanch said:
This 12,000 square feet of glass in a house has me baffled. Do you live in an 80,000 square foot house? :confused:
Lets just say floor to ceiling windows in a 10 foot tall single story room. That's 1200 feet of perimeter wall. My typical little 1700 SF home has about 180 LF of exterior wall. Not your cookie cutter suburban home. I think maybe a zero was dropped somewhere.
I have been fascinated with the listeroids for a long time but don't have the machining knowledge or tools needed to get one ready for operation.
I have lived through long term power outages with an oversized generator. 11HP gas engine screaming at 3600 rpm and consuming 1/2 gallon of fuel per hour to run a minimal load. Be careful not to oversize for the sake of fuel consumption and for health of the engine since diesels need to be worked to stay healthy.
   / Standby Generator - Diesel or NG? #54
kenmac said:
I perfer liquid cooled as opposed to air cooled
Curious as to how come? On a standby unit just less to go wrong or maintenance to keep up with. Biggest air cooled diesel I worked on was a V-12. Not a problem.
Just to keep in mind here you don't to run a standby gen 24/7. Especially in the south. The cold usually doesn't last that long so there is just some cooking and TV!!
   / Standby Generator - Diesel or NG? #55
In the south you also have to worry about hurricanes! After Hugo I hauled diesel in 5 gallon cans out to a 40kW for 19 days straight:eek: It was using around 10 gallons a day. Many homes were without power even longer than that. Mine has never been out more than 6 hours or so. I am on a well and that is my biggest problem, I can do without heat or cooling for awhile but I gotta have water;)
   / Standby Generator - Diesel or NG? #56
Ronmar- That Lister is really neat Kinda makes you want to run it just to listen to it and it is amazing how easy it starts. Best location for infor was ebay theres one for sale but out of my price range. Bought one of those big box Powermate Coleman 5k for a third of the cost of just the Lister engine. Glad I bought before I saw your post. :) Shipping alone was almost as much as I paid -Ed
   / Standby Generator - Diesel or NG? #57
Skyco said:
Ok. Getting back to what I said earlier in the thread one can haul their own diesel in 5 gallon cans if need be but one can't haul their own LP or NG :)
The point everyone else is making that except after an earthquake, there'd be no need to 'haul NG'.
Oops! too many zeros - 1200 square feet (50 units each 4ft x 6ft) of sealed units is a better number. The house is about 3000 square feet plus basement, all heated. I know that heat loss is not what mattters but my point was that when the temp is -20C and the wind is blowing at 100 km/h I need both FA furnaces running flat out. I am going to have my electrician come over and give me a better idea of how much generator capacity I should instal. After reading the various comments here I am now thinking a 20KW unit will be sufficient.
Thanks again for all the comments and suggestions.
   / Standby Generator - Diesel or NG? #59
Well yeah an earthquake could disable the NG system. But- you knew there would be a but right?- terrorism or as I previously mentioned rotating shutdowns of the NG could cause an outage too. Heck there have been several times in my area that backhoes or other digging equipment have disabled a pipeline, sometimes resulting in quite large conflagrations:cool:
The point I'm making is I tend not to depend on others for my welfare. I don't trust the pipeline companies or the electric companies, which in my area are the same entity, to always be 100% reliable. Did I mention I used to work for them;) Yeah they are pretty good, but not infallable by any means.
   / Standby Generator - Diesel or NG? #60
Never heard of rolling shutdown of NG pipelines. If there is no break then there is no need for a shutdown. Plenty of reserves comming into the pipeline. And with the pipeline underground, not many problems to deal with like power lines.
Sounds like a conspiracy!! :D
(APPROX 15) 2" X 6" X 68" TUBING (A54756)
(APPROX 15) 2" X...
1985 Miller Wildcat 350-D Welder (A51691)
1985 Miller...
2017 KENWORTH T680 SLEEPER TRUCK (A54313)
2017 KENWORTH T680...
UNUSED IRANCH HYD EXCAVATOR THUMB CLAMP (A54757)
UNUSED IRANCH HYD...
Kubota ZG327 (A50120)
2000 FORD F350 SUPER DUTY XLT FLATBED TRUCK (A54756)
2000 FORD F350...
