RonMar
Elite Member
He must if he needs a 40KW genset
Actually the ammount of glass dosn't really effect how much peak load he has, it just means that those peak loads involved with the heating and cooling run longer to make up for the energy lost out thru those windows. So he will burn more fuel keeping the temp at a particular level, than an equally sized structure with less glass.
I don't think this is your typical household. IMO I think he needs an actual-use energy study to properly size his generator. Then again, when you are talking about the money involved with even owning a structure this size, perhaps the cost difference between installing and operating a 20KW set vis a 40KW set might not even be worth the thought.
