Mowing Stalling when hot and engaging blades
   / Stalling when hot and engaging blades #1
727a Deere
727a John Deere zero turn mower
Stalling when gets hot and engaging blades
   / Stalling when hot and engaging blades #2
If the mower has a two cylinder engine make sure both cylinders are running. If you have one dead cylinder the mower will still run but power will be greatly diminished.
   / Stalling when hot and engaging blades #3
727a Deere
Welcome to TBN
Roadworthy likely correct, and the Kawasaki is only firing on one cylinder.
To check that, start it and then pull one plug wire off. If the engine dies, the other cylinder is not firing. If the engine continues to sound the same, then replace that plug wire and pull of the other one.
Please let us know what you find out.
John Deere 7000 12R 30" Planter (A50515)
John Deere 7000...
(NEW) 2025 DOWN 2 EARTH GOOSENECK TRAILER (A51243)
(NEW) 2025 DOWN 2...
10' Feed Bunk (A50515)
2006 John Deere 650J LGP Crawler Tractor Dozer (A50322)
2006 John Deere...
2014 UTILITY 53X102 DRY VAN TRAILER (A52141)
2014 UTILITY...
2004 Stage Line SL-250 Mobile Folding Stage Trailer (A50322)
2004 Stage Line...
