stack overflow errors
/ stack overflow errors #1
Soundguy
Old Timer
Central florida
RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
getitng a ton of stack overflow errors, appears to be related to adds loading.
only happening here.
nobody else seeing this? really?
/ stack overflow errors #3
Nope. What system/browser are you running?
ie8 windows xp when it was doing it.
get dialog boxes saying message from webpage, stak overflow. if you look at the bottom of the page you will see it is laoding an add. when you clear the dialog, andother add loads, and errors. usually does this a couple three times then stops.
i fiugure one of the add scripts is causing it.
doesn't do it on my phone.. on win8 phone and whatever built in ei it has.
/ stack overflow errors #5
I haven't seen an ad on TBN or anywhere else in many many moons.. Just load Adblock Plus in your browser. and ads go by by.
/ stack overflow errors #6
I don't believe the IE on XP can be brought up to current levels, or the OS itself for that matter. I suspect you don't have these issues on a current system. Yes?
ie8 is max for xp
I am not seeing it in win 8 phone, or win 8 rt.
Bottom line, there are still many thousands+ xp systems out there, no reason to get a web page error suddenly...
/ stack overflow errors #9
Sure there is ... As the programming languages evolve, new code can be introduced. My guess is your system is no longer in tune with the server's expectations. Just as something like Micro$oft Word is backwards incompatible between .doc and .docx filetypes. When it says "no longer supported" you can assume there will eventually be problems.
Now, I could be wrong - but - if it's working in Win 8 ... that's a clue :) Frankly, I liked XP Pro and considered it one of Micro$ofts best systems but there came a time to move along.
edit ... You "might want to try" .. check to see if you can install any updates to Java.
/ stack overflow errors #10
ie8 is max for xp
Yes there is. IE8 is the pits to write a working website for, they tried to keep the old IE only cruft from IE6 and IE7 while adding features to keep up with Firefox (who was eating their lunch).
Try installing Firefox, Chrome or adding https://adblockplus.org/releases/adblock-plus-11-for-internet-explorer-released to your IE.
Aaron Z
/ stack overflow errors #11
It happens. We run IE8 at work as we still have a few XP boxes left. Some of our legacy programs are not Win 7 or IE9 or higher compatible. I get the stack overflow occasionally from certain websites that are no longer IE8 compatible such as AOL. I am updating my last XP box at home today to Win 7. Something keeps crashing the desktop and I can't get it to keep recovered. It would appear that XP and IE8 will go by the wayside faster than when support ended for earlier operating systems such as Win 95, 98, or ME because of the programming difference from IE8 to IE9 and higher.
seems like it would be EZ to detectwhat the other system has and display accordingly. onthe oher hand. the forcefeed and clos your eyes method must be easier. ;)
the difference between a good programmer and a great one. ;)
/ stack overflow errors #13
But ... At what point would you free these guys from supporting a system that is already over 13 years old? Should they worry about people on Win95, from around 1990?
There comes a time when you, as a consumer, have to decide if being stubborn is in your best interest.
/ stack overflow errors #14
These days (with the WWW a little over 20 years old) we are practically back to the late 90's when it comes to browsers and how they render requests...(remember the "browser wars"?)
One of the biggest issues these days is semantic markup...before the push to using CSS almost all designers used tables (or in some cases "layers")...now days using tables for layout is a no-no if you want optimum SEO according to many search engines...
The problems lie with the way browsers render CSS layouts and the content they offer (including advertising)...i.e., what displays wonderfully on one browser (version) may not display the same on others...today's designers (webmasters) have to jump through hoops to get their designs to display the way they want on a majority of browsers...
For a long time M$ft (IE) refused to conform to WC3 standards and many versions still don't...
Today the biggest challenge is to make the same markup display on so many different screens/devices including touch/no touch applications...some designs require more RAM than older operating systems will support...
in some cases there is no compromising...
/ stack overflow errors #15
Yep. We had a website at work that took 3 weeks to build and make look good on Chrome, Firefox and IE 9. We then spent another 2-3 weeks making it work well on IE7 and IE 8. We made it work on IE 6 but the "bling" (rounded corners, nice fonts, etc) were not possible.
Aaron Z
i still access govt websites that require IE as a browser and support ie 6 standards.. ;) and when i said REQUIRE IE as a browser, they apaprently mean it.
I know it's possible to support older browsers. I still see some sites asking for netscape!!!
heck. even on win 8 phone, it's still a 50-50 toss up as to if i can post or just browse!, even using other browsers!!
win 8 rt seems to let me browse/post fine from the surface tablet..
2016 WEILER P385A ASPHALT PAVER (A62129)
2016 WEILER P385A...
Towable Pipe Road Crossing Trailer (A63689)
Towable Pipe Road...
YALE 60 MX STRAIGHT MAST FORKLIFT (A63276)
YALE 60 MX...
New/Unused Landhonor 26ft x 13ft Metal Carport (A65583)
New/Unused...
1999 Dorsey 42' Aluminum Citrus Trailer (A64127)
1999 Dorsey 42'...
2015 John Deere 210 GLC Excavator (A60352)
2015 John Deere...
