Backhoe Stabilizer bleeds off when stored
/ Stabilizer bleeds off when stored #1
fewebb100
Bend,Or
Kubota B7800
Question:
Storing my Kubota B7800 with the backhoe stabilizers in the up position, I find one of them has dropped down to the ground. No leaks, hydraulic fluid is full and clean.
What might cause this?
Thanks,
Fred
/ Stabilizer bleeds off when stored #2
Cylinder is letting a little fluid pass by the seal, pretty common. If it bleeds down in hours that's probably a bit too much, but if it takes days that's not surprising.
Thank's for your input guys.
Fred :)
/ Stabilizer bleeds off when stored #5
I had this happen and now use a rubber bungee to keep them up when stored.
Takes a few days for them to start dropping a little and then it goes fast because there is more leverage/weight as the arm extends.
One guy spent money to have his cylinders rebuilt and found the problem was in the spool valve control...
/ Stabilizer bleeds off when stored #6
Ratchet strap keeps em put during winter storage .:thumbsup:
/ Stabilizer bleeds off when stored #8
That's why the big Hoes... have locks on them. :D
/ Stabilizer bleeds off when stored #9
I really like the spring loaded stabilizer locks WaxMan made though..........
/ Stabilizer bleeds off when stored #10
MY out riggers had a hole through them so I put some eye bolts through the holes and use a piece of swing set chain to hook them together to keep them in the upright position. Works great.
/ Stabilizer bleeds off when stored #11
Check off another bungee cord user here!:thumbsup:
Hey Deano, Good idea using a bungy cord. Probably the next best thing to Duck Tape. :)
Thanks for the tip,
Fred :)
/ Stabilizer bleeds off when stored #13
Waxman definately has it going on, those look great.
/ Stabilizer bleeds off when stored #14
One of the stabilizers on my L48 leaks down to the ground in about 48 hours. The dealer rebuilt the cylinder with new seals - no difference. Don't waste your money doing the same.
I use the cheap ratchet strap method. A bungee cord on the L48 just won't hold those heavy stabilizers.
/ Stabilizer bleeds off when stored #15
Sorry... guys with "non" subcompacts need heavier solutions:ashamed::ashamed:
/ Stabilizer bleeds off when stored #16
I use a ratchet strap on mine as well. Works great
2001 International 4000 DT 466E (A60462)
2001 International...
KING 18 SHANK 3 BAR CHISEL PLOW (A63291)
KING 18 SHANK 3...
6 Band Wooden Barrel (A61574)
6 Band Wooden...
2001 FORD SUPER DUTY F350 4x4 UTILITY TRUCK (A59912)
2001 FORD SUPER...
1206 (A64280)
1206 (A64280)
YALE VERACITOR 50XV STRAIGHT MAST FORKLIFT (A64279)
YALE VERACITOR...
