Backhoe Stabilizer bleeds off when stored
/ Stabilizer bleeds off when stored #1
fewebb100
Bend,Or
Kubota B7800
Question:
Storing my Kubota B7800 with the backhoe stabilizers in the up position, I find one of them has dropped down to the ground. No leaks, hydraulic fluid is full and clean.
What might cause this?
Thanks,
Fred
/ Stabilizer bleeds off when stored #2
Cylinder is letting a little fluid pass by the seal, pretty common. If it bleeds down in hours that's probably a bit too much, but if it takes days that's not surprising.
Thank's for your input guys.
Fred :)
/ Stabilizer bleeds off when stored #5
I had this happen and now use a rubber bungee to keep them up when stored.
Takes a few days for them to start dropping a little and then it goes fast because there is more leverage/weight as the arm extends.
One guy spent money to have his cylinders rebuilt and found the problem was in the spool valve control...
/ Stabilizer bleeds off when stored #6
Ratchet strap keeps em put during winter storage .:thumbsup:
/ Stabilizer bleeds off when stored #8
That's why the big Hoes... have locks on them. :D
/ Stabilizer bleeds off when stored #9
I really like the spring loaded stabilizer locks WaxMan made though..........
/ Stabilizer bleeds off when stored #10
MY out riggers had a hole through them so I put some eye bolts through the holes and use a piece of swing set chain to hook them together to keep them in the upright position. Works great.
/ Stabilizer bleeds off when stored #11
Check off another bungee cord user here!:thumbsup:
Hey Deano, Good idea using a bungy cord. Probably the next best thing to Duck Tape. :)
Thanks for the tip,
Fred :)
/ Stabilizer bleeds off when stored #13
Waxman definately has it going on, those look great.
/ Stabilizer bleeds off when stored #14
One of the stabilizers on my L48 leaks down to the ground in about 48 hours. The dealer rebuilt the cylinder with new seals - no difference. Don't waste your money doing the same.
I use the cheap ratchet strap method. A bungee cord on the L48 just won't hold those heavy stabilizers.
/ Stabilizer bleeds off when stored #15
Sorry... guys with "non" subcompacts need heavier solutions:ashamed::ashamed:
/ Stabilizer bleeds off when stored #16
I use a ratchet strap on mine as well. Works great
2017 Ford Escape 4WD SUV (A61574)
2017 Ford Escape...
UNUSED SDLANCH ELECTRIC GOLF CART (A64280)
UNUSED SDLANCH...
UNUSED WOLVERINE UNIVERSAL MOUNTING PLATE (A64281)
UNUSED WOLVERINE...
UNUSED WOLVERINE RSB84-84" ROCK SCREENING BUCKET (A64281)
UNUSED WOLVERINE...
2025 Polaris Ranger XP1000 (A60462)
2025 Polaris...
2024 Kubota RTVXG850GLAS24-A Sidekick Utility Vehicle - 19 hours
2024 Kubota...
