Stability improvement
   / Stability improvement #1
Youare
Platinum Member
Winchester, New Hampshire
Kubota L3000
I have a Kubota L3000DT which I use some of the time to go into the woods to do some light logging, it has a Farmi winch on the back. I take out a few saw logs and a lot of fire wood.
I recently moved the rear wheels to the widest setting and the difference that has made in stability is notable. The difference in width is only about 6" on a side but that little bit makes a world of difference.
I would suggest that any one who drives their tractor on uneven ground set the wheel width to its maximum.
Randy
   / Stability improvement #2
It is surprising how much difference a few inches of added width will make in stability. I found loading the rear tires with liquid ballast also makes a dramatic difference in stability as well as traction.
MarkV
   / Stability improvement #3
Mark,
I also think that loading the tires makes a great improvement in stability and traction... It's far superior to wheel weights also....
Regards,
Chris
   / Stability improvement #4
How did you move the wheels? I have been comtemplating this but thought the weight of my rear wheels would be too much to handle without an overhead hoist. My tires are filled as well. I was planning on taking it in to my dealer for this.
Also, did you move the front out as well?
Chuck
2014 Ford F-150 Pickup Truck, VIN # 1FTFW1CT4EKG42947 (A51572)
2014 Ford F-150...
8ft Perforated Metal (A51573)
8ft Perforated...
2014 Acura ILX Sedan (A51694)
2014 Acura ILX...
2008 JLG 450AJ SERIES II MANLIFT (A51246)
2008 JLG 450AJ...
2014 TAKEUCHI TS70R WHEELED SKID STEER (A51246)
2014 TAKEUCHI...
AGT Mini SkidSteer (A50322)
AGT Mini SkidSteer...
