Stabalizer bar questions
/ Stabalizer bar questions #1
Bobby R
1972 Ford 2000
When I bought my Ford 2000 a couple of months ago, it only had one stabalizer bar on the 3-point. The guy I bought it from said that's all it needs. It seems to work okay with just the one when I'm brush hogging or blading, but all the tractors I've owned previously had a stabalizer bar on both sides. Is it necessary, or is just the one sufficient?
/ Stabalizer bar questions #3
1 will do 95% of the time. I've bent them using one when using a heavy bush hog on a bit of a hillside. 1 is good, 2 is better.....
Okay thanks, I was just wondering if I'd mess something up using just one. I don't have any hill sides to mow or anything like that and my brush hog is not that heavy.
/ Stabalizer bar questions #5
ditto what the others said. 1 works.. 2 better.
brackets and bars are cheap / easy to make, so it's no big deal to add the 2nd one.
soundguy
/ Stabalizer bar questions #6
soundguy
I was mowing yesterday and somehow snapped one of the stabilizer pins (under the fender) 2nd one held everything straight, but the bar that dropped now has a bit of a bend in it....
I feel a lot better with 2 in use.
/ Stabalizer bar questions #7
and i thought iw as the only one to plant stabilizer bars.. :) notic ethey never break at the implement.. but only at the tractor, then somehow spear right into the ground.. :)
mine usually get.. or used to get, the lynch pins snatched off.. till I switched to using cotter pins or keychain round split rings. those work great!
soundguy
/ Stabalizer bar questions #8
soundguy
They make lynch pins that are stronger than bear traps. You have to be careful of them or they will make your fingers pay the price!
/ Stabalizer bar questions #9
I thought those black ones were bear traps. I think they could get a bear by the toe and hold it there. They can snap you in bone breaking style going either way. I have a few and have put them where I'm not as likely to use them. I don't want to hurt myself (again).
2003 International 4300 Flatbed Dump (A62613)
2003 International...
2018 BOBCAT E50 EXCAVATOR (A64279)
2018 BOBCAT E50...
1998 Fontaine 48ft. 38 Ton T/A Flatbed Trailer (A61573)
1998 Fontaine...
2009 BMW Sedan (A61569)
2009 BMW Sedan...
FORD 5 BOTTOM SIMI MOUNT BOTTOM PLOW (A63291)
FORD 5 BOTTOM SIMI...
Auger Drill Bit Skid Steer Attachment (A61572)
Auger Drill Bit...
