SSQA to 3pt for the front of the tractor
   / SSQA to 3pt for the front of the tractor #21
Pallet forks would be one.
Some SSQA pallet forks come with extra rollback:
The one above also has gussets for the top of the QA plate, to prevent it from bending with a heavy load, like this one did:
After repair and gussets:
   / SSQA to 3pt for the front of the tractor #22
When doing some welding on my brush hog,
and one time this winter while trying to squeeze a 10" blade thru an 8" door that was also to short for the loader arms only 6 1/2 ' high but a few feet of clearance once past the door.
Also with the york rake curling back to hook and pull down a bunch of grape vine, wanting to go in under some branches then hook and pull down and out.
   / SSQA to 3pt for the front of the tractor #23
I have a set of Titan pallet forks and I can't see when I'd need more roll back on them. I have a box blade on order and I have a rake and it's possible that the increased roll back might be useful on them. I'll see what I can do with the parts I have. Might be a little while before I can get around to it and I'll try to remember to post a picture when I'm done.
   / SSQA to 3pt for the front of the tractor #24
I welded a QH to a SSQA plate to make a mount for my plow. It worked well for that. It was handy for other stuff like flail mower maintnance & the trailer mover too.
I have a spare QH & SSQA plate still. Keep planning on making another to replace the old one that ran off with the old L3200 & plow. I might add more rollback to the new one. It would decrease capacity with the lift hooks sticking out further. But there isnt much roll back if you just mount things flat.IMG_20150117_153833-1.jpgIMG_20150819_201502.jpgIMG_20150612_213855.jpg20161025_152850.jpgIMG_20150626_200301.jpg
2015 EAST MANUFACTURING ALUMINUM STEP DECK (A58214)
2015 EAST...
48ft all aluminum feather light wedge trailer (A56435)
48ft all aluminum...
2012 Ford Transit Connect Cargo Van (A56858)
2012 Ford Transit...
NEW Wolverine Skid Steer Auger Drive And Bit (A59000)
NEW Wolverine Skid...
1611 (A57192)
1611 (A57192)
CASE MXM 190 (A58214)
