Posthole Digger SSQA for L245DT with a 1200 Loader.
   / SSQA for L245DT with a 1200 Loader. #1
2458n
I have the need to purchase a piece from Kubota. Measurements of 37 5/8 outside and 33.5 inside. 1 inch pins on 9.5 inch centers. Where can I find the measurements on the internet?
   / SSQA for L245DT with a 1200 Loader. #2
Need more info. Are you trying to use a hydraulic post hole digger on the SSQA or trying to convert the loader to SSQA?
I would like to buy a ssqa for the 1200 loader. Measurement given is off my bucket ears. Would like to remove bucket and replace with a ssqa. I know there is something close available from Kubota. Nice day in Ohio - 72 degrees and nothing but sunshine. Farmers are spraying their cover crops and drilling in seedcorn today.
   / SSQA for L245DT with a 1200 Loader. #4
First step would be to call your local dealer.
There are several aftermarket businesses that make a SSQA Adapter, this is one: Hay Farm Equipment | Skidsteer Attachments | Hay Spear Attachments
Thank you for the Washburn info. Bought mine used 34 years ago at auction. From a John Deere guy. Replaced one water pump so far- no dealer really wants to waste time to take my money. Washburn has one close, will call tomorrow. They go down to 35 inches I need narrower. Thank you again for the info.
   / SSQA for L245DT with a 1200 Loader. #6
You are welcome.
They can make it to fit your loader.
   / SSQA for L245DT with a 1200 Loader. #7
First step would be to call your local dealer. There are several aftermarket businesses that make a SSQA Adapter, this is one: Hay Farm Equipment | Skidsteer Attachments | Hay Spear Attachments <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=465503"/> <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=465504"/>
I have one from them on my Ford 1920. It's nice and strong, but also heavy. I think mine weighs about 170 lbs. works great though. Mine is blue.
2015 FORD F-350 XL SUPER DUTY SERVICE TRUCK (A51406)
2015 FORD F-350 XL...
1065 (A53342)
1065 (A53342)
CUSHMAN HAULER PRO GAS GOLF CART (A51406)
CUSHMAN HAULER PRO...
2014 Ford Fusion SE Sedan (A53424)
2014 Ford Fusion...
Two Pairs of 10ft Fork Extensions (A53421)
Two Pairs of 10ft...
Pair 2 - ST225/75R15 radial trailer (A53421)
Pair 2 -...
