Posthole Digger SSQA for L245DT with a 1200 Loader.
   / SSQA for L245DT with a 1200 Loader. #1
2458n
I have the need to purchase a piece from Kubota. Measurements of 37 5/8 outside and 33.5 inside. 1 inch pins on 9.5 inch centers. Where can I find the measurements on the internet?
   / SSQA for L245DT with a 1200 Loader. #2
Need more info. Are you trying to use a hydraulic post hole digger on the SSQA or trying to convert the loader to SSQA?
I would like to buy a ssqa for the 1200 loader. Measurement given is off my bucket ears. Would like to remove bucket and replace with a ssqa. I know there is something close available from Kubota. Nice day in Ohio - 72 degrees and nothing but sunshine. Farmers are spraying their cover crops and drilling in seedcorn today.
   / SSQA for L245DT with a 1200 Loader. #4
First step would be to call your local dealer.
There are several aftermarket businesses that make a SSQA Adapter, this is one: Hay Farm Equipment | Skidsteer Attachments | Hay Spear Attachments
Thank you for the Washburn info. Bought mine used 34 years ago at auction. From a John Deere guy. Replaced one water pump so far- no dealer really wants to waste time to take my money. Washburn has one close, will call tomorrow. They go down to 35 inches I need narrower. Thank you again for the info.
   / SSQA for L245DT with a 1200 Loader. #6
You are welcome.
They can make it to fit your loader.
   / SSQA for L245DT with a 1200 Loader. #7
First step would be to call your local dealer. There are several aftermarket businesses that make a SSQA Adapter, this is one: Hay Farm Equipment | Skidsteer Attachments | Hay Spear Attachments <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=465503"/> <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=465504"/>
I have one from them on my Ford 1920. It's nice and strong, but also heavy. I think mine weighs about 170 lbs. works great though. Mine is blue.
2014 Nissan Altima S Sedan (A55853)
2014 Nissan Altima...
MINI ROCK CRUSHER SDLTC (A55745)
MINI ROCK CRUSHER...
2007 CATERPILLAR 725 OFF ROAD DUMP TRUCK (A52707)
2007 CATERPILLAR...
2015 PETERBILT 365 (A52472)
2015 PETERBILT 365...
2022 Polaris Ranger 900XP 4x4 Utility Cart (A55853)
2022 Polaris...
2017 Ford F-150 Crew Cab Pickup Truck with Liftgate (A55852)
2017 Ford F-150...
