SS stuck in snow twice, tire chains?
   / SS stuck in snow twice, tire chains? #11
Ya got to be very carefull with a SS. They have a ridgid frame (no suspension or axle movement) and unless it is on flat ground (not necessary level), you have only one wheel on each side firmly on the ground diagonal from each other, and 2 wheels "light" if not touching the ground at all. Imagine putting a 4 legged table down with one leg on the carpet with the others on the wood floor. That equals 2 wheel drive. Chain it up on all 4 corners. IIRC you just got this machine, you will come to know how to use it.:thumbsup:
   / SS stuck in snow twice, tire chains? #12
I like. :)
   / SS stuck in snow twice, tire chains? #13
My Cat 246 was a tire machine and it was not very good in the snow or mud. I bought a Loegering undercarriage with 18" tracks....it's a animal now.
   / SS stuck in snow twice, tire chains? #14
I used to get my old 2wd Ferguson tractor stuck all the time, year round. Most of the time I got it out with a come-a-long tied to a tree.
   / SS stuck in snow twice, tire chains? #16
Are there holes in the rims that you can run a bolt through? If so, you could bolt a single chain holding a 2 X 2 piece of scrap steel or lumber. I once chained a small wood fence post to my tractor tire and it got me out of the divot I had made. Just be really careful and stop after 25 % of one revolution of the spinning wheel.
   / SS stuck in snow twice, tire chains? #17
I used that trick once on my Ford 2N. Be very careful
   / SS stuck in snow twice, tire chains? #18
Traded Kubota tractors to GEHL3640e SS. Have 16" to 24" plus drifts on the ground. SS now stuck off drive in yard. Been stuck twice when I get off level drive, slides sideways or gets at angle (not level ground and I live on a hillside) and gets stuck. Also now remember why I moved from BX to B Kubota tractors, ground clearance.
Are tire chains the answer. Tires are 27x 8.5x 15HD. Deere on internet offering chains for $100 plus shipping. Ebay seller has them for $88 with shp but has for LT tires and mine are HD, does that make a difference for the chains?
Purchase larger diameter winter tires and wheels for your SS.
   / SS stuck in snow twice, tire chains? #19
   / SS stuck in snow twice, tire chains? #20
steel tracks the answer after you get unstuck....tractors to repair the damage from the tracks
2008 FORD F-350 (A50854)
2008 FORD F-350...
2008 FREIGHTLINER FLD120 SD DAYCAB (A50854)
2008 FREIGHTLINER...
2011 Kenworth T300 Jerr-Dan 21WSRB Rollback Truck (A49461)
2011 Kenworth T300...
2015 MACK GU713 (A50854)
2015 MACK GU713...
2016 GENIE GTH1056 TELESCOPIC FORKLIFT (A51242)
2016 GENIE GTH1056...
2020 Kubota Z723KH 48in. Zero Turn Commercial Mower (A50324)
2020 Kubota Z723KH...
