Squirrels and Mice
/ Squirrels and Mice #1
mrutkaus
Platinum Member
15 mi. N. of Winchester VA
Kioti CK30HST, Kubota BX-1500,
Advice needed on reality based methods to keep squirrels and mice etc out of engines. Not something you read somewhere, please, something that actually worked for you.
This is not a tractor but could have been, and might be. A '76 Mercedes 450SEL stored under a tarp.
Jaw Dropping, tried to start it a couple months ago, wouldn't start. Finally opened hood. Seven out of 8 plug wires (SS sheathing over core) eaten thru completely. Most of them in two places, ie, placing a 4" length of plug wire on the ground for each one. Looked like an assembly line operation. That was all, so I thought. How did they know to just eat the plug wires?
Spent a few hours routing and putting in new wires, car started, ran fine (after 5 months or so). Noticed battery wasn't charging.
Then looked more, found squirrels ate thru completely alternator wires under battery and a couple of other sensors.
Just about to put it all back together after soldering/splicing etc.
How can I keep them out? This is out in the woods fairly near the house.
Mike
Winchester VA
/ Squirrels and Mice #3
Lots of threads on here with various tried and true suggestions. A glass jar half full of mothballs, placed on top of the engine/fuel tank, along with leaving the hood open works for my tractor.
- Jay
/ Squirrels and Mice #4
Afternoon Mike,
Sorry to hear about all the aggravation the mice are giving you ! ;) My Uncle Dave stores his good car in the barn durring the winter months. He always leaves the hood up and car uncovered ! He also puts a couple of packets of unopened DeCon around the of the car, the mice if hungry will rip open the packets on their own. This has worked well for him, but if you have outside cats etc the DeCon could be a problem !
Thanks. Hood Open hadn't ocurred to me, maybe just a bit to take away the security that closed area must provide.
Mike
/ Squirrels and Mice #7
I have a classic car in a pole barn and the mice seem to find their way in through the door. I have sealed the sides.
I put several socks filled with moth balls under the hood in various places where there are wires. So far it has worked. I check it weekly too. I would do that too if I were you until your sure the fix is working.
I also put an open box of moth balls in my small tool shed out back where they like to nest and that seems to be working too.
/ Squirrels and Mice #8
mrutkaus said:
solo...confused where to put peanut butter...
I use a similar bucket trap, but have a teeter totter like board on the rim. Peanut butter goes on the far end of the teeter totter, over the water.
/ Squirrels and Mice #9
Mouse / rat traps. The spring types work well, but you have to check them pretty often. Bait stations are usually pretty effective, although you did mention not wanting to use chemical solutions... I like the baited bucket idea.
/ Squirrels and Mice #10
Spread the peanut butter on the inside of the bucket 2 or 3 inches from the top.
Solo
/ Squirrels and Mice #11
I posted a similar question here about a week ago. Mice were constantly making nests under the hood of my Kubota. The advice I got was to use mothballs and to leave the hood up. The day before I posted the question I had left the door to the fuel tank open. That little bit of openess (or lack of a closed space) discouraged nest buidling. So now I leave the hood up and mothballs near by. My tractor is in a barn though - not under a tarp. An open hood with a tarp over it may still give the pests a sense of security.
/ Squirrels and Mice #12
I use the bucket method. Have a tight nylon string going across the width of the bucket at about the level of the handle. (2-3" down from rim).
On the string is a water bottle. Mice are not brand snobs. Drill a small hole thru the cap and bottom, centered nice. Coat the outside of the bottle with peanut butter. Put a ramp up to the edge of the bucket, so the mice have to jump out to the center of the bucket. They hit the bottle, it spins and they go swimmies. Put about 3-4" of anti-freeze mix in the bucket. Used is ok and the environmentally safe stuff for RV's is ok too. It keeps the dead ones from stinking....
I have gotten as many as 12 in a week. I use it at my hunting camp too.
jb
/ Squirrels and Mice #13
Never would believe this until we tried it ... Used dryer sheets spread around the area you wish to be mouse free.
/ Squirrels and Mice #14
john_bud said:
Put about 3-4" of anti-freeze mix in the bucket. jb
I'm sure most folks will be careful with antifreeze. Dogs like the taste and it kills them if they drink it.
/ Squirrels and Mice #15
The phone company here sprays mace in the junction box every time they open it up. Seems to keep them out for about 2 months at a time.
/ Squirrels and Mice #16
If you have to store it outside I would suggest you go and get one of those "Shelters in a Box" They have a 12' x 20' at TSC for right at $300 and then you could put the car in leave the hood up and do all the other little things to keep the mice away. Plus you would be able to check it every one in awhile.
I am not sure how much money you spent correcting the problems this time around, but I would think it would be close if not more than the 300 bucks? Makes a good storage place for some of the summer items that aren't needed during the winter months.
Tractor Supply Company - ShelterLogic PREMIUM QUALITY OUTDOOR SHELTERS
/ Squirrels and Mice #17
I tried this in my mailbox when the rodents were being very persistent about nesting in there (terrorizing the mail person). By the time I tried the sheets though I think the rodents were just about ready to give up-- they did a bit of tearing of the sheet but did not build a nest (I used a cordless B&D blower to blow them out a few times before the dryer sheet, the blower really rattles them-- sneak up on the box, pop the door, and zzzzZZZZZZZZZZ out they fly with the nest. But I think they would have returned without the last repulsion of the dryer sheet. I did not want mail stinking of moth balls).
/ Squirrels and Mice #18
Yeah...I could just see Homeland Security on the board asking here, "Who told you to put mothballs on your mail?", after you sent in some of your bill payments and your mailed receipts set off some sort of security systems...:D
/ Squirrels and Mice #19
I have used the little plug-in repellers in my sheds and workshop for the past 15 years. They seem to keep the little buggers away.
They work best if you rid your place of any "squatters" first. Then the transmitters keep any tresspassers from wanting to stay.
I had such good luck with them at my prior residence, I immediately palced 3 of them in my 30x40 pole shop 4 yrs ago, upon it's completion.
Not one rodent found, to date. Knock wood.
Storytime: I had an 18hp gas Ford garden tractor w/48" mower deck that caught fire while I was mowing one fall, many, many years ago. Mouse nest on the exhaust manifold. Quite stinky. I looked like an old locomotive puffing smoke across the yard, heading for the garden "fire hose".
Those were the days! :rolleyes:
2000 Sterling L9511 Triaxle Dump Truck, VIN # 2FZNNWYB8YAB42893 (A65563)
2000 Sterling...
2020 CATERPILLAR 289D3 SKID STEER (A65053)
2020 CATERPILLAR...
Rotary Auger Motor Attachment (A61572)
Rotary Auger Motor...
2018 INTERNATIONAL LT SERIES (A65643)
2018 INTERNATIONAL...
Landhonor 3-Pt PTO Potato Harvester (A66285)
Landhonor 3-Pt PTO...
2012 FREIGHTLINER M2 6X4 T/A DAY CAB TRUCK (A66091)
2012 FREIGHTLINER...
