Squealing altenator
/ Squealing altenator #22
Quite common to use the alternator to messure rpm, in the Bosch world this connection is marked with a W.
/ Squealing altenator #23
I also once had strange "length" issues with a tractor fan/waterpump/alternator belt. For its first couple hundred hours, my Kubota belt stayed nice and snug. Then suddenly, I found it extremely loose, so much so that I had to adjust the alternator almost to the end of its travel. It's like the belt suddenly stretched by a HUGE amount. It's been ok since and hasn't stretched more.
/ Squealing altenator #24
Got a old 1980 fort pick up and it does the same thing squeals the belt on startup the belt is tight, and was adjusted with a belt tension gauge,
I just keep the RPM low, for a min or two, as the battery is recharged after the starting drain on it is relieved,
CATERPILLAR BACKHOE (A65053)
CATERPILLAR...
2012 Komatsu PC200LC-8 Hydraulic Excavator (A64194)
2012 Komatsu...
Stout Buckets XHD 84 Grapple Skid Steer Bucket (A65640)
Stout Buckets XHD...
2012 Ford E-350 16ft. Box Truck (A64556)
2012 Ford E-350...
2025 Unused SDLGC80 Electric Golf Cart (A64194)
2025 Unused...
3pt Countyline Auger w/Bit (A64126)
3pt Countyline...
