Squealer SQ480 rotary cutter with a bx22
   / Squealer SQ480 rotary cutter with a bx22 #1
Barneytyler
Has anyone tried using a Bush Hog SQ480 Rotary cutter along with a BX22? This is only a 4'' cutter, but exceeds the Max weight that Kubota recommends for the bx22. I believe that it weighs 440Lbs. If anyone has used this combo or other similar 4" cutters with the bx22 I would like to hear your results or problems.
   / Squealer SQ480 rotary cutter with a bx22 #2
I'm curious. What is the 3PH lift capacity on the BX22?
By the way, for comparison, the SQ420 weighs 356 pounds compared to the SQ480's 440 pounds
   / Squealer SQ480 rotary cutter with a bx22 #3
I use a Rhino SE-4 on my BX2200 without a problem. The SE-4 weighs 435 lbs. The hitch pins need to face inward, because the BX links don't have enough spread. This is pretty common when using implements on the subcompacts.
   / Squealer SQ480 rotary cutter with a bx22 #4
Barneytyler
Gsganzer (who is a customer of one of our stores) answered this question before I could. I have mentioned before about being "creative" when mounting some implements on the sub compact tractors and this is one of those instances. Actually, the pins on the SQ series are easier to relocate due to the way the mast in constructed.
Lewis
2025 12V Diesel Pump and Hose with Meter (A50324)
2025 12V Diesel...
2005 NEW HOLLAND DC95WT CRAWLER DOZER (A51406)
2005 NEW HOLLAND...
2014 FORD F-550 ROUSTABOUT(INOPERABLE) (A52472)
2014 FORD F-550...
Guard Rail Pieces (A51692)
Guard Rail Pieces...
2025 12V Diesel Pump and Hose (A50324)
2025 12V Diesel...
2012 KENWORTH T370 PROPANE TRANSPORTATION TRUCK (A52472)
2012 KENWORTH T370...
