Squealer SQ480 rotary cutter with a bx22
   / Squealer SQ480 rotary cutter with a bx22 #1
Barneytyler
Has anyone tried using a Bush Hog SQ480 Rotary cutter along with a BX22? This is only a 4'' cutter, but exceeds the Max weight that Kubota recommends for the bx22. I believe that it weighs 440Lbs. If anyone has used this combo or other similar 4" cutters with the bx22 I would like to hear your results or problems.
   / Squealer SQ480 rotary cutter with a bx22 #2
I'm curious. What is the 3PH lift capacity on the BX22?
By the way, for comparison, the SQ420 weighs 356 pounds compared to the SQ480's 440 pounds
   / Squealer SQ480 rotary cutter with a bx22 #3
I use a Rhino SE-4 on my BX2200 without a problem. The SE-4 weighs 435 lbs. The hitch pins need to face inward, because the BX links don't have enough spread. This is pretty common when using implements on the subcompacts.
   / Squealer SQ480 rotary cutter with a bx22 #4
Barneytyler
Gsganzer (who is a customer of one of our stores) answered this question before I could. I have mentioned before about being "creative" when mounting some implements on the sub compact tractors and this is one of those instances. Actually, the pins on the SQ series are easier to relocate due to the way the mast in constructed.
Lewis
2015 KENWORTH T800 (A52472)
2015 KENWORTH T800...
2012 PETERBILT 365(INOPERABLE) (A52472)
2012 PETERBILT...
New Wolverine72 In Skid Steer Brush Cutter (A53002)
New Wolverine72 In...
2013 Ford Expedition XLT SUV (A50324)
2013 Ford...
2009 HINO 185 18FT BOX TRUCK (A52577)
2009 HINO 185 18FT...
2015 Chevrolet Equinox 2LT SUV (A50324)
2015 Chevrolet...
