square tubing bender questions
   / square tubing bender questions #1
BAP
Walpole, NH
Kubota B2920 Loader, BH65, 60"MMM, B2782B snowblower, Forks , Woods 48" bush hog
I am looking to build a cab for my Kubota B2920. I plan to use square tubing either 1" or 3/4" square. What is a good affordable bender to buy for this project so I can shape the tubing to fit the contours of the tractor? I want something that will work for the job, but not necessarily "PRO" quality as I will probably only us it occasionaly after this project is done. Thanks for any advice or experience you can give me.
   / square tubing bender questions #2
Good question I will watch with interest as I might try to do it also
   / square tubing bender questions #5
I just angled the tube around the fenders. It worked pretty well. 3 pieces made the curve around the fender. Every thing else was straight.
   / square tubing bender questions #6
I would go and check out Northern Tool's tube benders ,they,ve got some at pretty good prices.
Some good ideas here. I will look at the pictures latter when "HopeFully" my internet is back to running high speed. Right now it is as bad or worse than dial-up.
2005 KOMATSU PC400LC-7L EXCAVATOR (A51246)
2005 KOMATSU...
2005 Ford F650 SVI Crew Cab Hazmat Truck (A52377)
2005 Ford F650 SVI...
2016 KOMATSU D61PXI-23 CRAWLER DOZER (A51246)
2016 KOMATSU...
UNUSED FUTURE HYD THUMB CLIP (A51248)
UNUSED FUTURE HYD...
Kubota KX91-3S2 Mini Excavator (A52377)
Kubota KX91-3S2...
2006 MACK GRANITE CV713 DUMP TRUCK (A51406)
2006 MACK GRANITE...
