square tubing bender questions
   / square tubing bender questions #1
BAP
Walpole, NH
Kubota B2920 Loader, BH65, 60"MMM, B2782B snowblower, Forks , Woods 48" bush hog
I am looking to build a cab for my Kubota B2920. I plan to use square tubing either 1" or 3/4" square. What is a good affordable bender to buy for this project so I can shape the tubing to fit the contours of the tractor? I want something that will work for the job, but not necessarily "PRO" quality as I will probably only us it occasionaly after this project is done. Thanks for any advice or experience you can give me.
   / square tubing bender questions #2
Good question I will watch with interest as I might try to do it also
   / square tubing bender questions #5
I just angled the tube around the fenders. It worked pretty well. 3 pieces made the curve around the fender. Every thing else was straight.
   / square tubing bender questions #6
I would go and check out Northern Tool's tube benders ,they,ve got some at pretty good prices.
Some good ideas here. I will look at the pictures latter when "HopeFully" my internet is back to running high speed. Right now it is as bad or worse than dial-up.
2011 Homesteader Box Trailer, 6'x10' (A52384)
2011 Homesteader...
2022 Case IH Steiger 470HD AFS Connect RowTrac 4WD Tractor (A50657)
2022 Case IH...
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
91013 (A48082)
91013 (A48082)
2020 Utility Trailer Manufacturing, 53' Trailer (A52384)
2020 Utility...
