spring project, VAC
/ spring project, VAC #41
worked on a alt stabilizer bracket. oem setup was obviously a gen.. and I had to play with brackets to get a alt wedged in.. wasn't ideal.. so added this for now..
here's the bracket, in the rough. this is with it test fit, no grinding or finish work has been done at this point. I literally cut, welded, torched and beato on it.. tdipped it in a water barel to cool, then slid on and added bolts and nuts to check fit.. then rain caught me.
will pull it off, gring, prime and paint.
Ah, brackets--fabricating those things can slow work down a lot. I just replaced the engine on my Bolens GT1453 garden tractor. Had to cut, drill and weld a new engine mount, fabricate new mount/brackets for the battery, and make a new handle with spring release to raise and lower the rototiller.
got a bit more work done so far..
thankya
/ spring project, VAC #45
Super result:thumbsup:
I like the looks of that alternator bracket. I'll use that design for future restorations with your permission.
Got the engine out of the 1948 Farmall Cub today.
Raining today. Hope to get it to the engine shop tomorrow.
that was one of those field expediaent, gotta make it work, fab jobs :)
hopefully your bracket will be more elegant than mine.. :)
/ spring project, VAC #47
The black air cleaner and stack looks surprisingly good on there.
/ spring project, VAC #48
Let's see. I have a Rigid floor type drill press with some good Milwaukee drill bits, a Ryobi 4-1/2" angle grinder and a Hobart Stickmate LX AC/DC welder. Can't get very elegant with that selection of tools but I'll try my best:eek:.
i used a stick welder, chop saw, angle grinder and drill press to make mine.. :) a hacksaw woulda worked for the chop saw :)
here's one after a victory drive around the pasture.
re adjusted the steering.. had it too tight before.
found she likes to warm up and idle for a minute or so before doing much.. after that she's game.. :)
/ spring project, VAC #51
What took you so long??? :D :laughing: ;) :thumbsup:
/ spring project, VAC #52
Coolio:thumbsup:. Looks like you have a real winner there.
Your efficiency has inspired me to crank up the volume and get my pending tractor restoration work done ASAP :).
/ spring project, VAC #53
If you weren't so far away, I'd send a couple projects your way.., LOL...
twas fun. I still have a few detail issues to work on.. might fab an oem looking pto shield.. etc.. etc..
/ spring project, VAC #55
that's a lawnmower gas tank feeding the carb.. :)
I have a generator from my 51 VAC that I had replaced with a alternater and a 12 volt system and electronic ignition. It was hard to start up north in winter with the 6 volt generator.
/ spring project, VAC #57
I took a bunch of pics of a nice VAC today, I'm posting in vintage tractor forum shortly. Let me know if you need any pics to reference and I'll send you high res.
done finished mine months ago.. but I'd love to see the pics nonetheless.. i'll look over in vintage.
80003CFL (A61568)
80003CFL (A61568)
2003 International 4300 Bucket Truck (A62613)
2003 International...
2008 INGERSOLL RAND G240-191KW GENERATOR (A63276)
2008 INGERSOLL...
JOHN DEERE 7330 PREMIUM TRACTOR (A64280)
JOHN DEERE 7330...
Power command Transfer Switch (A62679)
Power command...
Takeuchi TB225 (A62177)
Takeuchi TB225...
