spring loaded throttle?
   / spring loaded throttle? #11
Joe, if we're talking about the same spring (99810 in below diagram) that allows the governor to move the throttle linkage to the carburetor without moving the hand lever below the steering wheel.
My earlier post is germain to your original problem with the throttle lever not staying put.
   / spring loaded throttle? #12
ditto.
the OP needs to look at the bellcrank area....
   / spring loaded throttle? #13
Where is the nut located that tightens the spring? I have the same problem? I thing the threads are stripped though on the bolt. How would I fix it?
   / spring loaded throttle? #14
the bellcrank area?
do you guys have a manual? or even have the machine!!!!
use your eyes to follow the throttle linkage from the hand throttle to the top of the bellhousing .. you will find the bellcrank there with the spring and nut.
2016 FREIGHTLINER M2 REFRIGERATED BOX TRUCK (A51222)
2016 FREIGHTLINER...
2019 Ford F-250 4x4 Crew Cab Pickup Truck (A50323)
2019 Ford F-250...
2018 Dodge Charger Sedan (A50324)
2018 Dodge Charger...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
Walking Floor Trailer (A50322)
Walking Floor...
2015 JOHN DEERE 744K-II HIGH LIFT WHEEL LOADER (A51242)
2015 JOHN DEERE...
