spring loaded throttle?
   / spring loaded throttle? #11
Joe, if we're talking about the same spring (99810 in below diagram) that allows the governor to move the throttle linkage to the carburetor without moving the hand lever below the steering wheel.
My earlier post is germain to your original problem with the throttle lever not staying put.
   / spring loaded throttle? #12
ditto.
the OP needs to look at the bellcrank area....
   / spring loaded throttle? #13
Where is the nut located that tightens the spring? I have the same problem? I thing the threads are stripped though on the bolt. How would I fix it?
   / spring loaded throttle? #14
the bellcrank area?
do you guys have a manual? or even have the machine!!!!
use your eyes to follow the throttle linkage from the hand throttle to the top of the bellhousing .. you will find the bellcrank there with the spring and nut.
RoGator 844 sprayer (A50490)
RoGator 844...
2012 PETERBILT 388 SLEEPER TRUCK (A51222)
2012 PETERBILT 388...
Agro Trend 7' 3PT Snow Blower (A52349)
Agro Trend 7' 3PT...
2021 Liebherr L556 (A52128)
2021 Liebherr L556...
2022 CATERPILLAR 335 EXCAVATOR (A51242)
2022 CATERPILLAR...
2024 New Holland T8.410 MFWD Tractor (A52128)
2024 New Holland...
