Spring is Coming! Shall I buy a filter kit?
   / Spring is Coming! Shall I buy a filter kit? #1
Linda White
New Holland T6030
Hey, should I grab a filter kit for spring? I was lookin' up air filters and came across this site. Found a kit with a bunch of different filters. Now I’m thinkin’... am I actually gonna use all this, or just tossin’ cash away? :D
   / Spring is Coming! Shall I buy a filter kit? #2
I wouldn't. You didn't give us a link. Based on those prices I would be very leery of quality. I personally like to get them from OEM and I see you have a NH. Filters for my NH are expensive. I believe a complete filter change is more than $500. MUCH more expensive than JD which usually ends up being half the price. I
   / Spring is Coming! Shall I buy a filter kit? #3
I would definately do the maintenance and service my tractor and change the filters, however I like LHF 2019 am leery of no name filters, so I would seek some filters from Donaldson, Wix, Baldwin , etc or OEM filters if reasonably priced. Someone told me years ago always make time to do maintenance on your equipment or eventually it will make time for you, don't forget to grease everything while you are doing your maintenance, a nickle's worth of grease goes a long way, Good luck.
   / Spring is Coming! Shall I buy a filter kit? #5
If the tractor is still under warranty, I would buy OEM filters and lubricants from the dealer and maintain the sales receipts as proof of purchase should a warranty claim arise.
If the tractor is out or warranty, I would probably still buy OEM filters and lubricants from the dealer since peace of mind is worth something. That said, if the tractor is out of warranty I might check with NAPA or some other reputable vendor to see if a match at a lower cost is available.
Too much risk with no-name filters or lubricants to put an expensive piece of equipment in jeopardy.
Grease is cheap, parts ain't.
   / Spring is Coming! Shall I buy a filter kit? #6
That's not true...and if it is it should be stated in the warranty.
OP those all look like chinese no name filters. I wouldnt use them. Quality brand arnt much more. Baldwin, luber finder, champion, napa/wix, fram and Donaldson are all quality filters and have s good chance of being US made.
   / Spring is Coming! Shall I buy a filter kit? #7
I did not state it was necessary, I stated I would buy OEM filters and lubricants and maintain sales receipts as proof of purchase because I don't want to argue with a dealer/service manager.
My statement that I would buy OEM filters and lubricants is absolutely true. I made no claim about legalities.
You inferred something that is not there.
   / Spring is Coming! Shall I buy a filter kit? #8
Quite likely the outer filter will be dirty and the inner filter spotless.
It's good to have one of each extra on hand, but don't toss the inner filter "just because".
   / Spring is Coming! Shall I buy a filter kit? #9
I wouldn't risk expensive equipment on cheap no-name filters. These kits are generally cobbled together by God knows who, with little to no regard concerning OEM specifications.
   / Spring is Coming! Shall I buy a filter kit? #10
Some of those filter "kit" sites are known to have counterfeit Bobcat branded filters. They are marked as Bobcat but they are cheap knock-offs. Save a few bucks on filters in exchange of $10k of a fuel system rebuild? No way.
2018 Dodge Durango Multipurpose Vehicle (MPV), 175,918 Miles, Third-Row Seating (A56438)
2018 Dodge Durango...
SKIDDED FRAC TANK (A58214)
SKIDDED FRAC TANK...
2002 Ford F-550 Dump Truck, VIN # 1FDAF56F32EC86522 (A57453)
2002 Ford F-550...
2007 Ford F-550 Crew Cab 11ft Flatbed Truck (A55852)
2007 Ford F-550...
KUBOTA SSV65 OPEN STATION CAB (A52706)
KUBOTA SSV65 OPEN...
Utility Cart (A59228)
