Spreader spreaders
/ spreaders #21
Rich
Would you happen to Milky Spore is toxic to worms? I vaguely recall that either gophers or moles (can't remember which) live off grubs and eliminating the food supply is an easy way to eliminate the critter.
/ spreaders #22
Milky spore effects only grubs. It's harmless to worms and other critters. As far as moles, though, it indirectly gets rid of them, too. When you kill all the grubs, you get rid of the mole's favorite food source, and they move on.
Rich
/ spreaders
Say folks, it occured to me today that for winter snow pushing, it might be neat to leave the spreader attached and full of sand, salt, or some such stuff. Dual benefits.. extra traction, and the ability to spread the sand, etc.
However, a guy at the place I bought the Land Pride FS500 said he wouldn't advise this, as the spreader should really be cleaned out after each use.
What are your thoughts? Is it critical to clean after each use, or could it just be cleaned each time it needs re-filling? Of course this could mean it might not be cleaned for the entire winter. No way of predicting how much I would use or how often.
Thanks for any thoughts...
Bob
Bob Trevithick
/ spreaders #24
The problem with leaving salt in the spreader would be corrosion. The problem with leaving sand in it wouldn't be the sand, but the moisture it would/could contain, which would also cause corrosion.
/ spreaders #25
The reason I don't have a spreader currently is that several have been allowed to corrode to uselessness. They have to be carefully cleaned after each use. Lime, salt and fertilizer are all electrolytes, and everything holds water against the moving parts. You can't leave anything in them for very long.
Charlie Iliff
/ spreaders
<font color=blue>...The problem with leaving salt in the spreader would be corrosion. The problem with leaving sand in it wouldn't be the sand, but the moisture it would/could contain, which would also cause corrosion.</font color=blue>
Good point. I wonder though if the part which ended up corroding might be cheap and easily replaceable? I like this idea so much, I'm resisting giving it up. /w3tcompact/icons/smile.gif
Bob Trevithick
/ spreaders
Maybe a better idea would be a big box full of sand or salt, and a small shovel. It could be a great weight for traction, and still let me occassionally spread a little sand or salt on dangerous areas. It would also give me more control of where the stuff goes.
Anyone know of such a box with 3pt hitch mounts? Maybe I could have somebody weld me up one...
Thanks,
Bob
Bob Trevithick
/ spreaders #28
A couple things happen in the winter, usually spreading salt... you also have sand mixed... and then mother nature gives you a dose of moisture... mix it all up, the next day...[/i]it's usually frozen solid[/i]... now you have to break it up inside the mixer/spreader to work it...
Corrosion is the other problem, because even if you load just enough for usage, the salt eats it up wicked...again because of the moisture problem... and it's hard to "wash/rinse" the mixer out with water because it's winter.... {catch 22 situation}
Similar problem in summer, when spreading manure, it's very caustic, but at least you can wash/rinse out the mixer...
/ spreaders #29
TSC has a 3 pt platform you can put your own box on. I'm going to pick one up and build a flat pallet type platform on it to use as a carry-all. (they're cheap too - under $100)
mike
/ spreaders
<font color=blue>...TSC has a 3 pt platform you can put your own box on.</font color=blue>
I was thinking of the forklift type device.. maybe also put a pallet on it for anything like a big box of sand or salt. A friend tells me these are also handy for things like lifting rocks, etc.
My 3pt hitch is rated at 2200 lbs lift. Question, if I tried to lift something that was too heavy (it's hard to guess the weight of a rock) would I harm something, or would it just not be able to lift it?
Thanks for all the ideas, folks!
Bob Trevithick
/ spreaders #31
Sizing stones - I use 100#'s / cubic foot.
As for your 3pt ? - if you exceed the capacity of your 3pt no harm should be done, but you won't get any lift...
/ spreaders
<font color=blue>...TSC has a 3 pt platform you can put your own box on. I'm going to pick one up and build a flat pallet type platform on it to use as a carry-all. (they're cheap too - under $100)</font color=blue>
I was having a lot of trouble on the TSC site.. Opera 6.. then I tried it with Exploder, and it worked fine. However, I still can't find these 3pt platforms or forks. Can you give me a clue how to get to the right area?
Thanks...
Bob Trevithick
/ spreaders #33
Actually...I've never looked at their website 'cause they have 3 stores in my area - I pass 1 everyday to - from work, there's one just 10 miles from the house and another just a coupla miles from the office. .... I'll take a look and get back to ya --- maybe pick up a new catalog at the store ...
mike
/ spreaders #34
Bob, they call it a "Carry All"; it's on page 169 of the 2001 Blue Book, part #21-28202 for the one made by Wallace, and part #21-28210 for the one made by King Kutter.
/ spreaders
Ah, I think I found the perfect solution. A rear scoop! For winter snow plowing, I can just put a few bags of salt or sand, unopened, in the thing for some weight.. and in case I need the stuff. Then in the summer I can use it for moving dirt, rocks, etc. I found a thread somewhere where people were raving about the utility of these things, especially for someone who doesn't have a FEL.
Now I'll sit back and wait to hear the reasons why my brilliant new plan won't work. /w3tcompact/icons/smile.gif
Seriously, many thanks for all the advice and pointers!!
Bob
Bob Trevithick
/ spreaders #38
Bob, I don't have one of those scoops because I do have a front end loader, but if I didn't have the front end loader, I'm sure I'd buy the 3-point scoop; looks like a very handy implement.
Landhonor BH-12-72D Backhoe Skid Steer Mount (A62679)
Landhonor...
2014 CATERPILLAR 12M3 MOTOR GRADER (A64276)
2014 CATERPILLAR...
GASPARDO V-20-8 5 PANEL VEGETABLE VACUUM PLANTER (A64276)
GASPARDO V-20-8 5...
2022 CATERPILLAR 313GC EXCAVATOR (A65053)
2022 CATERPILLAR...
(INOP) 2002 CHEVROLET 3500 BUS (A59823)
(INOP) 2002...
2020 CATERPILLAR 306 CR EXCAVATOR (A60429)
2020 CATERPILLAR...
